Re: replace belt engine
ektor
I have replaced the belt engine by my self and I did a test...I try using a spanner on the crankshaft pulley and rotate the engine and it turns,but when I put it in the 5th gear and turn the wheel it did not turn.I am not sure if I can turn on the car because I am afraid that accures something wrong.please help me
Sean602
Re: Re: replace belt engine
when you put it in 5th gear you are trying to move the car - even the engine cant move the car from standstill in 5th gear - you have no chance with your spanner
as long as you followed the proper procedure and can turn the engine over a few times with nothing stopping it your going to have to be brave and start it
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
orange 2cv
red Dyane( in bits)
ektor
Sorry but I have dificulty understandig what you are saying. Please I want to know if the proccedure I follow with the spanner is ok? Because when I put the car in the 5th gear it blocked.thank you
Sean602
when in gear you are turning the gearbox
dont put it in gear and turn the engine over by hand to make sure the pistons dont hit the valves ?
whats your main language?
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
qprdude
- x 14
If you are turning the engine over using a spanner, surely the car needs to be in neutral . (not in gear).( Presume you are trying to turn the shaft through a complete revolution to check clearance.)
Rick.
2013 Citroen DS 5 D/Sport
ektor
I use a spanner on the crankshaft pulley and rotate the engine and it turns freely in neutral gear. But in the 5th gear the engine blocked.
Sean602
engine is not blocked
you are trying to make the engine drive 5th gear
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
Ben82
- x 7
Sean, seems to stem from Peters advice over here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=43876" onclick="window.open(this.href);return false;
2004 Citroen C5 3L V6 Auto
Sean602
ah! and lost in translation
still despite the language thing i do wonder why some people are allowed to buy spanners
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
- x 94
ektor
you have this same fault running in two threads
Regards, malcolm.
ektor
I start the car and everything is ok. Thank you to all for the advises.
- x 3296
Well done.
Sean602
Phiew! good man!ektor wrote:I start the car and everything is ok. Thank you to all for the advises.
kissing the lash
orange 2cv
red Dyane( in bits)
orange 2cv
red Dyane( in bits)
