c5 dmf or not
holmedog
- x 5
c5 dmf or not
Do all c5 1.6 hdi's have dmf or not as when i put my reg into part finders they come up with three part clutch kit.
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
- x 1480
Re: c5 dmf or not
Yes. It's still a 3 part clutch - the DMF is on TOP of that....and not cheap at that
Citroenmad
- x 110
Re: c5 dmf or not
As Richard has said, yes it does. Every diesel C5 has a DMF, unfortunately!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
flying clutchman
- x 3
Re: c5 dmf or not
And to make matters worse the 1.6hdi is a horrible job.
Citroenmad
- x 110
Re: c5 dmf or not
Worse than the 2.0 16v HDi?flying clutchman wrote:And to make matters worse the 1.6hdi is a horrible job.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
flying clutchman
- x 3
Re: c5 dmf or not
Well generally the 1.6hdi in all the PSA vehicles is the worst to do, however in the C5 you MIGHT be a bit better off because the larger car MIGHT allow you to get the front heatshield off ok. As you can guess I've not actually done one, but I have done the 1.6hdi on Picasso, P307 and they are a real pig. Firstly you cant get the heatshield off. When you have eventually managed to bend, hammer and drag it off you have to undo the turbo downpipe. Then you find you have to remove the downpipe fixing bracket and then you can..... oh no you can't you have to remove the stud that holds the bracket so that you can undo the ONE bellhousing bolt that fits right to left. This bolt doesn't ever go back! Of course the advantage may be that this engine comes mated to a BE4 type gearbox which will drop out easy enough. I really hate these because you feel some idiot designer sitting in his little office decided to put a single bolt round the other way, changing 30 years of design practice. Rant over!
Citroenmad
- x 110
Re: c5 dmf or not
Seems quite involved!
When I had the clutch done on my 2.0HDi 16v the subframe had to come down. Not a job I was wanting to do so it was farmed out.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1480
Re: c5 dmf or not
"When I had the clutch done on my 2.0HDi 16v the subframe had to come down."
Nah, it's possible without. Tiiiiiight though
The placing of the PAS return pipe is ludicrous though.....
- x 1056
Re: c5 dmf or not
I'm pretty sure the 90 bhp HDi doesent have a DMF.Citroenmad wrote:As Richard has said, yes it does. Every diesel C5 has a DMF, unfortunately!
