air in fuel system
b21playa
air in fuel system
Unread post by b21playa »
i have air in the sytem cuz it smokes up in the morning. its not the g glow plugs.
if i prime the fuel system, i have no problems
someone said to open the screw on the inlet pipe, but i cant find it
can someone show mwe a pic or explain to me
i have the bosch pump
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You have air leaking into the fuel line. Use of the hand primer to start confirms the diagnosis. Opening the bleed valve won't help. What you need to do is trace the leak. If your fuel filter has a plastic top, the seal could be faulty. If you haven't changed the filter, do it at the same time as checking the joint. Also inspect and replace any copper washers at banjo joints.
b21playa
ive changed the filter and i 4got to tighten the drain pipe and its seemed to sucked in more air
soneone must know how to do it
its really important
my first day at work in the morning. HELP
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JohnD</i>
ive used the hand primer and it starts first time with no smoke, no its defo air
ive changed he fuel filter and its seems tight, where is the bleed screw by the way, i have a bosch pump
Dave Burns
x 3
Unread post by Dave Burns »
There wont be a bleed screw, there hasn't been one for some years now, nor is there any need for one as bleeding is continuous via the pump outlet restricter, the fact that you have primed it with the hand pump and got it to start means that the air was purged from the pump anyway, so a bleed nipple wouldn't help much.
If this is a recuring problem then as JohnD has said you deffinately have air getting in, this often enters the system at the injector leak off pipes, removal of the intercooler if its a turbo version will be required to gain access the them.
Some models had an automatic bleed valve between the supply pipe and the return pipe, they don't often go wrong but when they do its best to get rid of them alltogether and pipe it straight through.
If you are relying on it in the moring don't go fannying about with it now, at least you know it will start after priming, if you go meddeling without knowing what you are doing you may well have a non starter.
Dave
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Burns</i>
Dave
i have replaced one section of the injector leak off pipes. shall i just replace them all??
also where can i get more piping from?
rich_spens
Unread post by rich_spens »
I had a similar problem with my 306 TD - sent it to a diesel specialist who adjusted the fuel pump timing and since then it's started with no smoke
b21playa
it says in the haynes manual, page 4D-3 and i quote
1. to prime the system, loosen the bleed screw located in the injection pump inlet pipe union bolt
2. pump the priming pump until fuel free from air bubbles emerges from the bleed screw. retighte the bleed screw
NOW WHERE IS THIS BLEED SCREW. I HAVE THE BOSCH PUMP AND I CAN NOT FIND IT.
does it look like a normal screw or what???
x 1486
Just becuase Haynes says it's there doesn't mean it is! Haynes was written with one particular car, and probably the manufacturer's service manuals at the time. Manufacturers keep thinkering with things, so they may not always be fitted. As Dave has pointed out, later cars are 'self bleeding' - just pump the primer till it goes hard, then start the engine and run for a while to bleed the air out.
If you think / know you are getting air in then you have to find the source - no easy task - just bleeding it out will not cure the problem.
b21playa
just had a look at the main inlet banjo, and there seems to be a little diesel arnd the copper ring and nut
could this be the problem??
how do i seal it?
JohnD
(Donor 2022)
x 72
Banjo unions are a favourite for air leaks. Get a couple of new copper washers for it.
b21playa
if i open the banjo's, will the fuel drip ??
do i have the stop fuel somehow first?
where can i get copper rings?
batwad
Unread post by batwad »
Stick some rag around the union and pump to catch any drips. I disconnected the fuel line from the fuel filter and wedged a piece of dowl in the end of the pipe to keep any fuel in the line, but I don't think there was a great deal.
Careful when tightening the union bolt back up, they shear easily (as I found out) and will cost you 77p and a day without a car while Peugeot order them in [:)]
excel789
Unread post by excel789 »
So let me get this straight, if there's no air in the fuel does that mean the primer bulb should be hard all the time?
JohnD
(Donor 2022)
x 72
Not exactly hard - but difficult to squeeze.
