tyres
duncan bladen
tyres
Unread post by duncan bladen »
probably get loads of advice saying dont etc , but looking for part worn tyres 185/65/15 hr
anyone know a place or link ?
1st french car : pug 306 1996 1.9 xld
2nd french car ; ren megane 2001 1400 16v classic
3rd french car : cit xsara ph1 hdi 5dr 2000
current car : cit xsara picasso hdi 2003
imperial21
Re: tyres
Unread post by imperial21 »
Hi
should nt be hard to find, have you tried ebay ?
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
duncan bladen
Re: tyres
there are a few , but doesnt seem to be any in North east
x 5673
Re: tyres
Duncan, there is a decent place in Birtley.
CT Tyres
Little lockup on the junction of Mary Avenue and Windsor Road.
duncan bladen
Re: tyres
ahh cheers steve , i will have a dodge down in the week
Northern_Mike
Re: tyres
duncan bladen wrote:probably get loads of advice saying dont etc , but looking for part worn tyres 185/65/15 hr
I don't really see the issue with part-worns as long as you get a chance to have a quick look at them before they go on and they're a reasonable brand.
Everyone buys a set of part worns when they buy a secondhand car... I know some are obsessive and change them all immediately, but most don't..
duncan bladen
Re: tyres
in these austere times i see this market growing
not many ppl , can afford 4 new boots these days
x 3296
Re: tyres
Something you might want to try is your local scrappie. I did (being somewhat short of readdies), and got 4 185/65R15 for £80 (fitted onto the rims), and balanced for another £20. The scrappie didn't have any Xantias, but I got the tyres off a Renault Scenic. I had to get them swapped over between rims as the Scenic has different bolt hole placement.
You have to inspect the tyres yourself thoroughly, as it is a case of "Buyer Beware", but the ones I got are pretty good.
andy5
(Donor 2022)
x 103
Re: tyres
Unread post by andy5 »
duncan bladen wrote:in these austere times i see this market growing
True, but once you've got going you only need buy two at a time.
When the fronts are worn out the rears go forward and a new pair go on the back.
My slight variation of that is I've had 2 spares and usually get new tyres fitted on loose wheels, which is a bit cheaper and can sometimes gain on the queue when all the bays are busy.
Northern_Mike
Re: tyres
Hell Razor5543 wrote:Something you might want to try is your local scrappie. I did (being somewhat short of readdies), and got 4 185/65R15 for £80 (fitted onto the rims), and balanced for another £20. .
Should you find yourself in this position again James, there's a place in Slough near M4 junction 7. All his part worns are £15 fitted and balanced...
Sent from my GT-I9300 using Tapatalk 2
Northern_Mike
Re: tyres
When the fronts are worn out the rears go forward and a new pair go on the .
Sadly being 4wd, my Subaru ruins 4 at a time...
C5Alan
Re: tyres
Unread post by C5Alan »
Next time your in a taxi ask them where they get their tyres many run part worms from the same breakers I use you see them up there all the time my thinking is if they good enough for them good enough for me
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
