Had the Xantia HDI a few months now and the fuel consumption is a bit higher than I was hoping for so I've checked the air filter, seems ok, and after a bit of googling it would appear that cleaning the MAF is something I should try. I've located it downstream of the air filter but there don't seem to be any obvious retaining screws or bolts, how is it removed?
I've got some Maplins switch cleaner, I presume this is the right stuff, or is contact cleaner something different?
Would easi-start be a step too far?
Anything else I should be looking at? I'm certainly going to give it some slick 50 fuel system treatment when funds allow.
Cheers
Paul
Need to clean the MAF
isisalar
- x 3
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
- x 1489
Re: Need to clean the MAF
It's just held in my the jubilee clips on a Xantia. What's it doing to the gallon - my estate has returned a pretty steady 45 in the near 100k miles I've had it....
waynedance
- x 8
Someone used Forte intake cleaner stuff on mine and it knackered it so be cautious.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
isisalar
- x 3
I'm getting about 36-38 I think,a lot of under 12 mile journeys,with a roof rack,and quite a bit of 50-60mph A road/motorway driving.
Is the MAF a complete unit then? Video's show a small unit being removed from the trunking.
I'm going to be very gentle with it, plenty of warnings.
Cheers
Paul
Cheers
Paul
mds141
Only use cleaner specifically for MAF sensors. Just type 'maf cleaner' into an ebay search and it should list products made by CRC.
Mark Smith.
1989 Citroen BX Gti 16 valve.
2000 Citroen XM VSX 2.1 TD.
- x 8400
mds141 wrote:Only use cleaner specifically for MAF sensors. Just type 'maf cleaner' into an ebay search and it should list products made by CRC.
There's interesting Mark. Never knew there was special MAF cleaners. How well do they work?
mds141
The MAF specific cleaners don't leave any residue, which I suspect brake cleaner and the like do. Cleaned mine last year and the cleaner certainly removes a lot of built up deposits. If you search on YouTube there are some clips. Sorry hopeless at posting links!!
Mark Smith.
- x 3296
If you cannot get hold of any MAF cleaner, contact cleaner probably would work. I would not use switch cleaner though, as some of them have a lubricant added to allow the switch contacts to slide cleanly across, and this might inhibit the MAF sensor.
- x 1240
I used Easystart to clean mine, very volatile stuff and it evaporates very quickly.
andy5
- x 103
Out of interest, what does it actually look like in there? I assume it's two hot wires or two thermistors, one behind the other, connected to a bridge circuit which measures the difference between them, but I could be wrong
Onlinemyglaren
- x 5672
