Hi guys,
I have done a search and slightly confused by what I see so I hope you don't mind me asking this.
I have dual-zone climate control in my 2002 Exclusive 2.0l 16V Automatic. For a while I have occasionaly felt what I thought was a draft in the car which seemed to stop it warming up. Tonight after going to grab something I bought on Ebay after work, I figured it out. As I got in the car to go home, I quickly hooked my phone up to a charging lead and ran the (thankfully long) cable to the power point. As I did this I suddenly thought - uh oh... why is the heater blowing cold air? I glanced at the temp gauage and it was fine, then I realised it was only cold on one side of the centre vent. The passenger side was blowing cold air, the drivers hot air. This then explains the draft i thought.
I read on here about a cog or something stripping which can cause this problem, but others also hooked it up to a lexia for a test as well. My only access to a lexia is my local repairer (and he will charge me), so I am wondering short of that - that are the most common faults and are they easy to diagnose/fix? Is it something someone with basic skills can do - bear in mind the height of cars "maintenance" is changing filters, fitting car stereos/audio equipment and topping up fluids normally - tho I have striped the rear boot catch to components, cleaned it and got it working again.
I want to fix this quickly if I can and just want to know what to look for and how easy it is.
Max
Citroen C5 2002 dual-zone climate control fault
MaxPrimal
2008 RENAULT LAGUNA 3 EXPRESSION DCI 130 - Satnav, Bluetooth and more...
- x 94
Re: Citroen C5 2002 dual-zone climate control fault
have you looked at the DIS-LEXIA location map in the link below
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Regards, malcolm.
- x 1240
Sounds like a faulty servo motor, I have a similar problem with mine, the passenger side is hot all the time, I have heard of the 'stripped gear' syndrome but haven't investigated mine yet.
waynedance
- x 8
I had the same problem and was the servo that controls the air flow.
There is a modified part from the dealer with a longer shaft.
A search on here should get you some pics and a part number. The dealer had know idea of the modified part so I had to quote part number.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
waynedance
- x 8
http://www.frenchcarforum.co.uk/forum/v ... =3&t=32780" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... 69#p331869" onclick="window.open(this.href);return false;
This should help.
This should help.
MaxPrimal
Thanks for the info. Is this bit easy to get to and replace or is it something for the more technically minded or general mechanic/enthusiast (none of which I am)?
waynedance
- x 8
Took me ten minutes to change is very easy.
Located in the passenger side on side of heater box. I would remove first to confirm the fault.
MaxPrimal
Thanks. I will try and get a look at it this week if I can get a couple of hours spare to deal with it.
MaxPrimal
Okay, Going to ask stupid question now: Where is this? I know where the heater controls are, I know where the internal pollen filter is. That is about it. Can you guide me as to where I need to look for this thing?waynedance wrote:Took me ten minutes to change is very easy.
Max
waynedance
- x 8
Ok on the side where the pollen filter is there is a piece of trim that needs removing and then you should see the motors on the side of the heater box. Now it has been a while since I done this so not to sure which motor it was as there a few that look the same. I think there is some info in one of the links I posted.
waynedance
- x 8
The piece of trim that I think you need to remove is on the side of the centre console, hope that helps
waynedance
- x 8
Ok just looked at the links I sent you and it seems you remove the glove box which is really easy to gain access to the motor, I did say it had been a while since I done it.
