1.9TD Temptation 2 Xantia had it for a year today 31st Dec
ashy90
Re: 1.9TD Temptation 2 Xantia had it for a month now
Unread post by ashy90 »
Yes deffinately get the belt looked at. If in doubt, replace. If it fails it is going to cost a lot more money to sort out than a simple belt renewal.
CGATCX25GTITURBO
x 16
Unread post by CGATCX25GTITURBO »
I looked at the belts, they look fine, no cracking anything, they are like the rest of the car like new, none of the rubber or plastic on this car is brittle, hoses, returns cables, clips.
All these are very supple, the car cruised at 000 on the way home, and has had the nuts revved off it for the MOT, I'll let you tell me so when it goes bang :)
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
x 3298
That is a sweet looking car, with an immaculate engine bay. It would be a shame if a belt were to fail and spoil it. Belt kits would not be expensive, whereas a motorway failure doesn't bear thinking about.
Just because a belt looks sound does not mean it is. Look what happened to Richard Hammond in that jet car. It was inspected before each run, and still the OSF tyre blew. It was believed that the tyre had blistered on the previous run, and this would only became visible when the tyre got hot. The next time it got hot was on the next run, and by the time it was known there was a problem it was too late.
Citroenmad
x 110
Unread post by Citroenmad »
Well I wouldn't be trusting that and for what it costs to do a belt chamnge its hardly worth the risk. It would be a shame if it went!
Out of interest, when do you plan on replacing the belts? As its well past recommended interval.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
CGATCX25GTITURBO
x 16
Hell Razor5543 wrote:That is a sweet looking car, with an immaculate engine bay. It would be a shame if a belt were to fail and spoil it. Belt kits would not be expensive, whereas a motorway failure doesn't bear thinking about.
if we worried about eveything that could go wrong we wouldn't do anything, as you say it was inspected and still blew, even new things break.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
CGATCX25GTITURBO
x 16
Citroenmad wrote:Well I wouldn't be trusting that and for what it costs to do a belt chamnge its hardly worth the risk. It would be a shame if it went!
13 quid and a couple of hours, I can think of better things to do with my time and money
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Citroenmad
x 110
I'm going to take that as a joke and think you are doing the timing belt imminently :lol:
03 Seat Arosa 1.0S
Northern_Mike
m
CGATCX25GTITURBO
x 16
No, I think I may use this to test the theory and dispell the myth about swapping 'aged' belts I'll do a monthly check and see if there is any change in the appearance of it, unless it fails first then I'll know I should have changed it. I changed my BX belts at 36 and 72k with no signs of failure, I bought the BX with 27k on it when it was 12 years old, the cam belt was changed over a year later.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
bxzx16v
x 34
Unread post by bxzx16v »
Surely it can't be the original belt ! It should be in the bin if it is along with the aux belt too .
Mark
CGATCX25GTITURBO
x 16
it's signed by Andre on the belt
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Citroening
x 19
Unread post by Citroening »
Teaching grandmother to suck eggs comes to mind - Neil can do what he wants regarding the belt as he's one of the most knowledgeable people within Citroen circles. See CGAT for evidence!
I know of a few instances of mega-low mileage cars being kept on the original belts and them being fine. Some of you may remember that 6800 Mile BX we had - a whip off of the two 8mm nuts of the belt cover revealed the condition appeared fine with no fraying, cracking or splitting. I understand that the inside cannot be seen however exterior condition is also important... It drove perfectly fine including going to the DSM and back - davetherave can certify that we weren't hanging about either. Drove like a new car... These time-warp cars really are amazing - looking at the pics Neil it reminds me of that BX condition-wise.
There was one chap I can remember (not on forums) that asked about the belt and physically recoiled and walked off straight after when I said it was on the original belt.
As mentioned it is obviously up to Neil what he wants to do. First thoughts are that the TD is quite a lazy engine in comparison to an engine like an Mi16 which are screamers - thus I would say that less stress would be put on the belt due to being an oil burner than a high revving petrol screamer.
Franklin
CGATCX25GTITURBO
x 16
I've got a good one from the BX still that is newer, and it's only done 36k so it should be ok for another 10k, will that be safer?
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
ashy90
CGATCX25GTITURBO wrote:I've got a good one from the BX still that is newer, and it's only done 36k so it should be ok for another 10k, will that be safer?
Are you talking about fitting a used timing belt, or am I missing something? :shock:
CGATCX25GTITURBO
x 16
I see it as tried and tested 'not used'
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
