Wiring 406 coupe
Lighty
x 35
Wiring 406 coupe
Unread post by Lighty »
A little help required from any electricians please [-o<
The car is an 03 Pug 406 coupe with a 2.2 diesel and Bosch EDC 15 ecu. It is blowing fuse F8 in the underbonnet board, this is for "engine management". I have traced the fault down to two white wires from the board that appear to go straight to the ECU to pins C3 &B4. The wire numbers seem to be CMO4A and maybe 1763 (hard to read). I currently have no wiring diagrams and no electrician, so any help would be gratefully received :?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 1044
Re: Wiring 406 coupe
Unread post by wheeler »
Is it full multiplexed (with COM2000) ?
Lighty
x 35
Yes the car has comms 2000 & is multiplexed
Citroen C15
Citroen Ami
x 1044
Im trying to cross reference this with a C5 diagram as i dont have any peugeot ones. What is the connector colour & pin numbers on the under bonnet fusebox where the wires come out & you say pins C3 & B4 at the ECU ? what colour connector ? the black, brown or grey ?
Can you double check the wire numbers as so far im havin no luck finding them, if the numer is not very clear strip the tape back a bit further as the numer is printed all the way along the wire.
spider
x 77
Unread post by spider »
I'll see if I can find a diagram later as I don't have access at the moment to check.
Andy.
Lighty
x 35
Ok guys , the problem wire is CMO4F, the other no is a 1732, which refers to it being white I guess as its on the other white wire. The other one is 9006 which goes to the DLC connector & isn't used
Ecu pic
Fuse box
Citroen C15
Citroen Ami
x 1044
CM04A appears to go straight from pin 12 of the 16 way green connector straight to pin C3 of the 32 way grey connector, try disconnecting it at both ends & see if it has continuity to earth.
As far as 1732 goes i cant find any reference to it on the injection system wiring diagram (from autodata). Where is this wire ? What component, connector colour & pin number ?
