Xantia - Replacing the cooling fan harness
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I need to replace the cooling fan harness , how complicate is it ? Is there any thread describing how to do this ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 8412
Re: Xantia - Replacing the cooling fan harness
Why do you need to do this Zohar?
It will be quite difficult ad it might be easier to repair what you have rather than try to replace...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
There is that short harness from under the fusebox to the cooling fan housing - do you mean that one?
x 8412
Zohar,
These circuits may jsut give you some idea of the loom replacement problem.
Although for an S1 Activa, the diagrams will apply to most S1 Xantias...
Fans Circuit Diagram
Fans Harness Diagram - The important one as it shows the looms/harnesses as they exist physically...
And finally, the locations of the various components..
Hope that helps Zohar...
lancia58
(Donor 2022)
x 8
One of the relay’s pin welded to the relay socket. I fixed this by cutting the wire and crimped a new terminal. For now it is OK, but from my experience it will happen again with the other relays . I have to opportunity to get a used harness, cleaned it and renew the electrical contacts and I want to install it.
Regards
Zohar
lancia58
(Donor 2022)
x 8
Thanks Jim the “locations” link is exactly what I need . Addo in that “locations” link it is the loom marked as E096 in the G square . It looks like I have to detach the frame that the fan motors are attached to. Can this be done without removing the front bumper ?
Zohar
addo
x 95
No, it requires removal of the bumper, frame face, undoing two 5mm internal hex head bolts on the AC joiner down low (make sure the correct two - don't lose all the gas!) and then decoupling of the radiator/condenser from the fan mounting.
lancia58
(Donor 2022)
x 8
How do I remove the bumper ?
Thaks
Zohar
x 8412
lancia58 wrote:How do I remove the bumper ?
It's easy enough Zohar, provided rust as not go hold of the mounting bolts...
Remove indicators and grille.
Remove the 13mm (10mm on s2 cars) bolts on the sides of the bumper sides. These can be accessed from the bungs in the front wing arch liners. Give them a good spray with Plus Gas as these are the ones that can be a bit of a challenge due to rust build-up on their threads.
Then, remove the three 10mm bolts on the underskirt and then pull the bumper forward, disconnecting the foglight electrics as you go.
If you have a car with headlamp washers you will need to disconnect the water feed ope to the washer jets - there’s a quick-release coupling to make this easy...
Think that's it. Sorry if I've missed a step or two... All from memory...
