identify fuel filter
duncan bladen
trying to identify if i have bosch or siemens fuel filter , as no markings on housing .......
has 3 fuel pipes , and an electrical connection , can anyone help?
1st french car : pug 306 1996 1.9 xld
2nd french car ; ren megane 2001 1400 16v classic
3rd french car : cit xsara ph1 hdi 5dr 2000
current car : cit xsara picasso hdi 2003
Onlinemyglaren
- x 5672
Re: identify fuel filter
May help if you could post a photo Duncan.
You will find it helps if you put the details of your car in your signature, saves people having to ask and you repeatedly having to supply the same information.
- x 1489
Ignore the filter to ID it - Bosch has an in-tank electric pump, Siemens doesn't. So if there is a hand primer under the bonnet it's Siemens(*), if not, and you can hear the pump whirring for a few seconds at swtich on, it's Bosch.
* unless it's a 1.6HDi in which case they all have a hand primer, not sure of the maker of the injection system.
citroenxm
- Fallen Hero
- x 70
The filter type is also irrelevent! Because the Bosch fuel system has had two types depending on year used!
I know the type of filter you have - its round at both ends, however, this filter was fitted to Bosch Fuel systems from 2001 onwards...406, C5 etc
Earlyer Bosch systems had a different filter and the housing had NO electrical sensor, to look at it fits in the house one way as the bottom has a funny shape to it, so it only goes in one way. This filter house has two pipes on the "Lid" or top, and a 22mm type hex head to use a socket to undo it. Fitted to Earlyer 406's (I think) and Xantias (Defenatly)
Your type of filter is bolted to a bracket by two 10mm nuts, and has a screw type lid??
Im dooing this by recall from your housing description... Am I right?
If im correct, dealer pt. no.. VFF422
Ive got the page up, but Ive no idea how to get it on here....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
duncan bladen
will try and get a pic , and have a look in daylight , not when almost dark , ta very much
Northern_Mike
Does it look like this one?duncan bladen wrote:will try and get a pic , and have a look in daylight , not when almost dark , ta very much
That's the Siemens one in my Berlingo HDI
citroenxm
- Fallen Hero
- x 70
They are ALSO fitted on the 406 and C5's with Bosch Mike!
So its a mix n match ... But thats the one he means..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Northern_Mike
That's definitely a Siemens as the Bosch filter wouldn't physically fit.
citroenxm
- Fallen Hero
- x 70
Yes Mike, what Im saying is that Sieamans fuel filter house is ALSO fitted to 406 and C5s after 2001 with Bosch fuel system..
So that fuel Filter house is NOT a dedicated Siemans filter house...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Northern_Mike
Yes, but only the Siemens filter will fit in it, so even though it's fitted to Bosch systems, only a Siemens filter will fit, so it is a Siemens housing..citroenxm wrote:Yes Mike, what Im saying is that Sieamans fuel filter house is ALSO fitted to 406 and C5s after 2001 with Bosch fuel system..
citroenxm
- Fallen Hero
- x 70
Ahh I SEE... Im with you now... So that sort is the Siemans filter, the other the Bosch filter...
Right.. I didnt realise that sort was known as the Siemans filter...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
duncan bladen
look exactly right, so its a siemans filter i need
Northern_Mike
duncan bladen wrote:look exactly right, so its a siemans filter i need
I think it's described at places like Eurocarparts as a "Siemens element type". The one I used was a Guttman brand like this...
http://www.eurocarparts.com/ecp/c/Citro ... 8a8&000140" onclick="window.open(this.href);return false;
But the one I used on the C5 just came in a Bosch box and said Bosch on it.
Onlinemyglaren
- x 5672
That's the same as my C5. I have a Mann W712/47 filter in it, sourced at Cocker's car spares, Columbia.
duncan bladen
THANKS ALL
