While changing oil, oil filter and the air filter today I noticed a bit of water in the bottom of the air intake box so took the opportunity of checking the MAF plus I'd already noticed I have intermitent loss of power going up steep hills, have to cog down into 2nd while other times fly up in 3rd.
I sprayed the MAF with switch cleaner and wiped gently with a cloth but found the finer of the two element is broken -
suspect I helped it break as the EML came on 20 seconds or so after starting up the car. The car still drove okay with a very slight delay when accelerating.
Any advice please on where to source another MAF at reasonable cost? Also will the engine be affected at different speeds / fule economy / go into limp home mode etc...
Thanks Jeff
MAF sensor C5 2001 2lt HDI
Jeff
Currently driving Citroen c5 2.0 HDI 51 Plate
Re: MAF sensor C5 2001 2lt HDI
I bought mine for that same model off Ebay, obviously a non original part at around £30ish but it's worked fine now for two years.
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40" onclick="window.open(this.href);return false;
- x 5672
The wires are very delicate and the lightest touch will break them, as will dropping the MAF.
Jeff
Gibbo,
Did you buy yours from the uk or abroad? I see from Hong Kong listed on one of the cheaper suppliers but would prefer buying from uk if possible?
I rang a scrappy today and he wanted £30 for a MAF which he will pull off a car if/ when i get there, when I mentiond they could be bought for £30.00 off ebay he said they were after market as if to say vastly inferior? But yours has lasted 2 years and counting?
Thanks for any advice given
Jeff
Jeff
Jeff
Have not had time to get a replacement MAF sensor sorted out yet.
Driving home tonight after doing a total of 28 miles since the MAF was damaged - now getting an intermittent audible beeping sound with "SPEED TOO HIGH" message on the dash, only doing 20-30mph.
Is this as bad as it gets as I probably wont replace the MAF sensor until the weekend?
Does anyone know?
Does anyone know?
- x 5672
The "Speed Too High" is not related to the MAF - it is selected from the menu and is (presumably - never tried) able to be adjusted.Jeff wrote: now getting an intermittent audible beeping sound with "SPEED TOO HIGH" message on the dash, only doing 20-30mph.
Mine is set at 30mph in case I get too enthusiastic driving around town.
Scroll through the menu and deselect it or adjust to your preference.
Jeff
Thanks myglaren, you've put my mind at rest.
