c5 spheres
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Have you checked Fleabay lately? There's often old stock of C5 spheres going for £40 and upwards. Again, though - it pays to have a pressure tester.
bill196510
Re: c5 spheres
Unread post by bill196510 »
I prob wont be able to get them off
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
oneday
Re: c5 spheres
Unread post by oneday »
is that for all 6
306 1.4 LX MERIDIAN
x 3296
Re: c5 spheres
Yes, but it does include fitting, so removal is not an issue.
oneday
Re: c5 spheres
it says on the site they will check yours so you may not need to replace them all
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
Anyone out there to fit spheres at reasonable cost:(
Wont be for a few weeks though
oneday
Re: c5 spheres
you buy the tool and i.ll give you a hand
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
Cheers, shall I buy the 4 corners first
oneday
Re: c5 spheres
i think you had better ask the advice of the more experiaced hydroactive people on here for that advice mine is the basic hydractive i think yours will be the plus system. but i have changed them on a xantia i had a few years ago cant be any worse than that i,ll bring the lexia to depressurse the system when needed
306 1.4 LX MERIDIAN
oneday
Re: c5 spheres
check this on ebay 110999258521
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
Back is soft, front hard, but still harsh over bumps at back
bill196510
Re: c5 spheres
Dont say c5 though
oneday
Re: c5 spheres
says he can make c5 one if wanted
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
Messaged him:D
x 1240
Re: c5 spheres
Unread post by Peter.N. »
Specify the C5 one as a Xantia/XM one won't fit, the C5 spheres are larger. Removal and refitting are more or less the same as the Xantia except you have to depressurise the system which involves some plastic pipe and a container, although when you do the front ones the bleed nipple is quite near the fluid reservoir so with a short length of pipe you can bleed the fluid off straight back into the reservoir.
