Wheel nut key damaged
oneday
Re: Wheel nut key damaged
if you lived around here you would have lost your car 5 years ago and they would be queing up for the wheels now. i went to work a couple of months ago and every drain cover was missing for about 2 miles even the ones in the middle of the roads.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
spako
I'm based in Barnsley but I don't think any key would match the locking nut.horsedentist wrote:where are you based I have a brand new key that might undo it as there is no wear on it yet.
2011 Renault Megane Sport Tourer 1.5 dCi 110 Expression+ Silver
oneday
all keys are made different so no other key will fit.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Lenny
- x 63
If you're really stuck then these chaps will be able to help.
A few years ago they removed one for me in about 2 minutes.
http://www.dynomec.co.uk/
Not a million miles away from you either.
den169
Similer ones on my c5 luckily the car came with two locking key nuts,But first time i went to a tyre place they said throw them away alloys are not worth nicking nowadays.I didn't but never tighten them too much,One way of getting them off is to very carefully weld some rod to the bolt in the wheel then weld a nut on the end ,My mechanic son inlaw has just done this last week on a corsa the woman who owned it had been driving it 8 months not knowing the locking key nut was missing.
hirameuser
This happened to me a couple of months ago. Tried all that has been mentioned in the prior posts. The socket hammed on did not work as the round post is waisted and designed to break which it did. As they are sunken into the wheel no space to weld a rod onto it. Special tyre fitters tool did not work. Drilling didnot work even with colbolt drills and lube. what worked for three of the nuts was getting a welder build up metal on the worn pins. The last one was by now so mullered I had to cut the spokes of the alloy then us an angle grinder to cut through the stud from the side.
One hell of a lot of trouble. I now have standard wheel nuts fitted and am looking for a cheep 14 spoke 15" wheel.
My advice once you have the the studs off throw them away and use standard nuts, if you are in a dodgey area buy some other style of locking nut, they are only about £20.00, my mechanic said this style of locking nut always gives trouble in the end.
Cheers
Phil
Cheers
Phil
spako
I've tried undoing the nut using socket on top but the center bolt came off as per the photos.
I've just ordered a screw extractor set and 4 OEM wheel nuts.
Now need to order some left hand drill bits - any recommendation on size?
- x 5674
Just taken my car round to my son's place. It has been left unlocked outside here for the past three days.oneday wrote:if you lived around here you would have lost your car 5 years ago and they would be queing up for the wheels now. i went to work a couple of months ago and every drain cover was missing for about 2 miles even the ones in the middle of the roads.
No locking wheelnuts either.
Tools left in sight as the rear shelf is removed for him to get his bike in. Rear seats folded down.
DickieG
- Monaco's youngest playboy
- x 33
You're tempting fate Steve.myglaren wrote:Just taken my car round to my son's place. It has been left unlocked outside here for the past three days.oneday wrote:if you lived around here you would have lost your car 5 years ago and they would be queing up for the wheels now. i went to work a couple of months ago and every drain cover was missing for about 2 miles even the ones in the middle of the roads.
Trust me here guys whilst some area's suffer higher levels of crime than others you shouldn't be surprised to hear that criminals can drive cars so matter how remote you are, sooner or later scumbags will pass by your way
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 5674
The C5 is the first car I have bothered locking. I generally do lock it overnight but it stands all day at work with the keys in it so I know where they are.
It is protected by the double chevrons
Someone wandered in to one of the units a month ago, into an office, swiped the manager's keys from his pocket and knicked his Focus - mid afternoon!
It was my son had left it unlocked when he dropped it here 7am on Friday. He is usually very diligent about locking up and has locked me out of the house several times as I rarely lock the doors if I am not actually at work.
I'm often at my daughter's, in the next street. He comes along, finds the house unlocked and leaves, locking it behind him and locking me out. Shame my daughter hasn't a spare key, really must remedy that one day.
