I wanted to bleed my brakes today when I realised that my wheel nut key is damaged - one pin is missing and another one is loose.
I managed to loosen 3 of 4 wheel nuts using the damaged key but there is not enough grip on the last one.
Quick trip to my local Citroen dealer confirmed the price of a new key - £58.60.
The thing is that I'm not sure if the locking nuts are the original ones hence I'm not prepared to risk this money.
Any idea how I can remove the last nut without spending a fortune?
Wheel nut key damaged
spako
2011 Renault Megane Sport Tourer 1.5 dCi 110 Expression+ Silver
oneday
Re: Wheel nut key damaged
have you got a pic of the nut
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Northern_Mike
Usual solution is to get a 1/2" drive socket slightly smaller than the locking nut, and use a large hammer to belt it on. Once it's on, use a breaker bar to remove it.
spako
I've just taken photos of the nut and key...oneday wrote:have you got a pic of the nut
spako
Don't think it would work on this type of screw.Rattiva_Mike wrote:Usual solution is to get a 1/2" drive socket slightly smaller than the locking nut, and use a large hammer to belt it on. Once it's on, use a breaker bar to remove it.
oneday
mikes method will work if you have the space to get a socket on the other way is to take it to a tyre fitting place and ask them to remove it. its well worn never seen one that bad. have a new set ready to put on.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Northern_Mike
Looks very similar to the ones on my old Activa that needed the hammer and socket treatment. Worked just fine.spako wrote:Don't think it would work on this type of screw.Rattiva_Mike wrote:Usual solution is to get a 1/2" drive socket slightly smaller than the locking nut, and use a large hammer to belt it on. Once it's on, use a breaker bar to remove it.
spako
Am I right thinking that the OEM alloys require the flat seat nuts like these:oneday wrote:mikes method will work if you have the space to get a socket on the other way is to take it to a tyre fitting place and ask them to remove it. its well worn never seen one that bad. have a new set ready to put on.
http://www.ebay.co.uk/itm/Citroen-C5-Lo ... 5d2e6b10b0
oneday
mine are alloys and they have the flat washer
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
vibes
First thing I did when I bought that C5 of mine I threw those locking bolts as far as I could and got a set of regulars. If someone wants to steal those original Citroen rims then be my guest
Of course situation here in Finland might differ from other countries.
In Finland we have this thing called Reilu Meininki
2005 C5 V6 Exclusive A Break
oneday
just been out and had a look at mine the same locking bolts as yours you will be able to use miks method on them plenty of room
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
oneday
[quote][/quote]First thing I did when I bought that C5 of mine I threw those locking bolts as far as I could and got a set of regulars. If someone wants to steal those original Citroen rims then be my guest
this is britain if you turn your back its gone
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
daviemck2006
- x 485
That looks exactly the same as the ones I had on my old C5. After trying loads of things including sockets and big hammers, specialist nut removers, universal things, ended up with the drill and about 6 bits and a large amount of swearing to get the last one off. Try slackening the other three nuts and driving the car. You might be lucky and slacken it off, or break it. Not at 70 on a motorway though!!!!!!!!!!!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
horsedentist
where are you based I have a brand new key that might undo it as there is no wear on it yet.
Northern_Mike
Not down here it's not. I've rarely locked my car in 5 years of living here, and I only live 6 miles out of the centre of Reading. I've just ordered 4 replacement standard wheel bolts for my C5 then I can remove the lockers. They're a total pain in the bottom.oneday wrote:First thing I did when I bought that C5 of mine I threw those locking bolts as far as I could and got a set of regulars. If someone wants to steal those original Citroen rims then be my guest
