im going to fit a towbar and a 13 pin socket. ive seen on ebay a relay that is to be used with a multiplex system for the lighting. am i right in thinking the split charger is just a standard system and is there anything else i should know about.
im hopeing to get the ecu remapped this weekend to get the low end pulling power sorted
c5 fitting towbar
oneday
c5 fitting towbar
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
JohnD
- x 72
Re: c5 fitting towbar
I fitted a towbar to my C5 back in 2005 but used a 12N and a 12S socket. I also used Towsure's Smart7 for the road lights and a Smartcom for fridge and battery charging. To ensure good fridge performance you need wiring of at least 2mm². I used two 17amp wires directly from the battery with suitable fuses fitted close to the battery. To avoid making holes in the bulkhead, I took the wires down the back of the engine bay, under the car, threading the wires through the fuel conduit. The wires entered through the fuel pump grommet and into the cargo area. The two relays are in one of the 'cupboards' in the boot.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
oneday
thankyou john i was wondering where to root the wiring
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
