dirty windows
oneday
dirty windows
Unread post by oneday »
is there anthing better for cleaning car glass than meths and paper.
306 1.4 LX MERIDIAN
Northern_Mike
Re: dirty windows
White vinegar and newspaper, about a 1:5 solution, in a bucket. Yes, you need to buy a few bottles of vinegar, but the value stuff from Tesco does the job well. I've never had any luck cleaning windows with meths, but vinegar always works.
Someone bought me a bottle of Rain-X Window cleaner and rain repellent a couple of weeks ago. I've been using that on the C5, very good it is too. No squealing wipers, no crud sticking to the screen in the freezing temps last week. £2.99 for a spray bottle of it from our local Asda.
oneday
Re: dirty windows
thanks i,ll give that a go
306 1.4 LX MERIDIAN
isisalar
x 3
Re: dirty windows
Unread post by isisalar »
I used rain x on my old Xantia once and it made the wipers judder. Never managed to cure it.
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 8408
Re: dirty windows
isisalar wrote:I used rain x on my old Xantia once and it made the wipers judder. Never managed to cure it.
I've found Rain X a complete waste of time and money... Sorry Mike...
The best for cleaning windscreens inside and out I find is a good strong solvent. The stuff they use in the electronics world seems to do the job a treat... Electrolube ULS is my favourite for the job...
Brake Cleaner might also be good although I've not yet tried it...
DickieG
Monaco's youngest playboy
x 33
Re: dirty windows
Unread post by DickieG »
Juddering wipers are invariably down to the wiper arms not holding the blade at 90° to the screen causing only one side of the blade to wipe the screen which in turn means that in one direction the blade is being "pushed" rather than flipping over and being pulled across the screen. Long story short, giving the wiper arm a twist along its axis in the appropriate direction normally sorts it out.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The problems I've had with Rain-X were solved by a late member of the local car club. He pointed out it was the grease in locust corpses (victims of high speed impact on the screen) that bonded well with the Rain-X to be extra stuck...
An alcohol based cleaner gets some things off, as does a good car washing detergent (without wax); I also clay bar my outside glass at times. Ammonia based cleaners shift stuff the alcohol or detergent often doesn't really move. Fallout removers also have a place, as minerals can bond well to the outside of glazing.
Inside I seem to mostly use ammonia based cleaners except on tint film where it ruins it, also acetone sometimes (again, not on tint). Meths and water solutions for the tint film ones.
TooMany2cvs
Re:
Unread post by TooMany2cvs »
I've always found that using a household squirt gun of glass cleaner and a wodge of kitchen roll does the job just fine, inside or out. <shrug> It's glass, after all... No need for anything more exotic or difficult or expensive to source.
Adrian
toomany2cvs (a) gmail.com
A miscellany of motorised silliness, from 0.75bhp to 9ft tall.
http://www.WhereverTheRoadGoes.com" onclick="window.open(this.href);return false;
x 1240
Re: dirty windows
Unread post by Peter.N. »
I use Tesco window cleaner - its brilliant.
x 5672
Re: Re:
TooMany2cvs wrote:I've always found that using a household squirt gun of glass cleaner and a wodge of kitchen roll does the job just fine, inside or out. <shrug> It's glass, after all... No need for anything more exotic or difficult or expensive to source.
Among other things I use an industrial glass cleaner (I work in double glazing manufacture) It works but the effects don't last more than a couple of days.
Northern_Mike
Re: dirty windows
I agree Jim, until I tried the new spray/cleaner that they seem to have brought out. Works well enough to be of use. More interesting to me is the fact it stops frost sticking to the windows, which makes my cleaning of the frozen windows on the way out of a nightshift so much easier.
The old stuff was cack on windscreens, but worked well on my helmet visor.
Northern_Mike
Re: Re:
I used to do this until someone bought me the bottle of Rain-X cleaner. I'll likely to go back to doing it when it runs out. Tesco value glass cleaner.
oneday
Re: dirty windows
tried the white vinegar can report it works a treet
306 1.4 LX MERIDIAN
