Does anyone know of anyone that does this kind of work at all?
Im looking to get a conrod made for an aircompressor which has failed so the original is available to use as a pattern as well as its balancing weight so it can be made to specs or the weight shaved up or down as needed?
CNC/Engingeering works in manchester/warrington
Re: CNC/Engingeering works in manchester/warrington
im hoping for something a lot cheaper just for a conrod thats about 3" long to be done otherwise the unit is scrap which is a shame really
None what so ever im afraid Adam
so i spoz you have exhausted the route of surfing the net for a new/second hand con rod,
what make and model is the compressor
Regards, malcolm.
Compressor is standard fitment to range rover l322's from 2005-2009
No online source for them
Will get the make off it later to help out
