It had a new caliber fitted to that brake about 3 months back, the pads were fine then. Getting down but healthy otherwise. So I did know they were due for replacing
Citroenmads Citroen blog.
Citroenmad
- x 110
Re: Citroenmads Citroen blog.
I was a little alarmed at the state of that pad
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 94
i dont know he hasnt polished the pad back plate with the discs yet JimCitroJim wrote:Nobody can ever accuse you of not getting your full moneys-worth out of a set of pads Chris![]()
Must be that Northern thrift coming out...
Regards, malcolm.
- x 8263
citronut wrote: i dont know he hasnt polished the pad back plate with the discs yet Jim![]()
That's true Malcolm and I see there's still a bit of friction material left. At least another 10 miles in those pads...
daviemck2006
- x 496
10? Us scots would have got another 10,000
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
Citroenmad
- x 110
That is why you never buy a car from Scotlanddaviemck2006 wrote:10? Us scots would have got another 10,000![]()
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Northern_Mike
I know an Indian Welder and have a tree. Does that help?Citroenmad wrote:I bet that was an interesting moment Jim![]()
I've had a scare in my Activa, all my own fault for pressing on a little too much. Taught me the limits of the car and my drivingI'll just say, there is no mystery as to why I've gotten through tyres so quickly
It's going to be the elephant I'm going to struggle with there, I don't see too many around here. I'll have to think of a substitute
Citroenmad
- x 110
It could well be worth a tryRattiva_Mike wrote:I know an Indian Welder and have a tree. Does that help?Citroenmad wrote:I bet that was an interesting moment Jim![]()
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
chopper602
- x 7
Might be worthwhile fitting indicator and main beam warning lights - the wires are already there, just need a couple of little dash lights (If you can get some from a GS/A all the better as they're a perfect fit) and you're good to go.Citroenmad wrote: I might sped a bit more time doing some jobs on the 2cv tomorrow, in between some Uni work no doubt. The dashboard is out at the moment, revealing a ton of wires which once went somewhere and had a use, but now just look like a safety hazard. They need sorting and finding out what does what before I put the speedo back in. There is a replacement fuel gauge on the way, which should hopefully fix the temperamental registering.
Tim
Teesside
1985 Citroën 2CV6
2011 Saab 9-5 2.0 TiD
2012 TEC RoTec Lift 652G Motorhome
2012 Toyota GT86
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
- x 8263
So, doesn't the 2CV have those lights as standard?
I thought those were mandatory on all cars
Northern_Mike
It's an "after a certain age" requirement as far as I know. I never had MOT problems with any of my 2cvs. You really don't need an indicator tell tale in a 2cv!CitroJim wrote:So, doesn't the 2CV have those lights as standard?
Sent from my GT-I9300 using Tapatalk 2
chopper602
- x 7
It's nice to have though, you can't really hear the 'ticker' anyway !!Rattiva_Mike wrote:It's an "after a certain age" requirement as far as I know. I never had MOT problems with any of my 2cvs. You really don't need an indicator tell tale in a 2cv!CitroJim wrote:So, doesn't the 2CV have those lights as standard?
Tim
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
Citroenmad
- x 110
Yep, it had the indicator warning light but it was an aftermarket light and unsigntly. The main beam light had been attempted but it didn't work. As many things didn't! Not that there is much on a 2cv, but this one had hopless wiring. Luckily we had some spare light fittings on a spare Club dash.chopper602 wrote:Might be worthwhile fitting indicator and main beam warning lights - the wires are already there, just need a couple of little dash lights (If you can get some from a GS/A all the better as they're a perfect fit) and you're good to go.Citroenmad wrote: I might sped a bit more time doing some jobs on the 2cv tomorrow, in between some Uni work no doubt. The dashboard is out at the moment, revealing a ton of wires which once went somewhere and had a use, but now just look like a safety hazard. They need sorting and finding out what does what before I put the speedo back in. There is a replacement fuel gauge on the way, which should hopefully fix the temperamental registering.
Its hard to tell what was standard with this 2cv.CitroJim wrote:So, doesn't the 2CV have those lights as standard?
I forgot to take any before pictures. But think of a badly painted metal backing plate which had once been painted white, once been painted blue and then very badly painted black. Oh, and the switches, nuts and screws had also been painted! There were badly placed switched and warning lights too.
With the help of a friend, it now has a new dash backing plate, some replacement switches and a lot of new wiring! The fog light has a replacement switch and is now working correctly. The high beam light is correctly installed and works. The indicator flasher clicks and works the same light as the hazards (two seperate lights before). There is a working oil pressure light. The fuel gauage has been replaced with a fully working one. The bulbs have been repalced and are much brighter. And we did get the heated rear window working but there is only one element which heats. So I've not bothered placing a switch for that as its not worth putting another hole in the dash for it as it doesnt work.
Its looking much better:
The green wire is now not there.
It wasn't without its hassles though. The original wiring was so bad that, on a second trial attempt at the functions, the car and under bonnet filled with smoke
I'll have to take some better pictures and of the seats too, which are looking much better and are so much more comfortable.
Im pretty sure I could have almost had the dash out and back in on a Xantia in the time that lot took
Two weeks yesterday is the 2cvGB Raid Tan Hill event, which I will be attending in the Beachcomber. Ought to be after all these hours on the seats, dash and carb
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
chopper602
- x 7
So are you doing the full run from Leeds or just meeting up with them at Tan Hill or Hawes?Citroenmad wrote: Two weeks yesterday is the 2cvGB Raid Tan Hill event, which I will be attending in the Beachcomber. Ought to be after all these hours on the seats, dash and carb
Tim
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
Citroenmad
- x 110
I would suspect meeting at Hawes, its what we have done previously. The drive drom there to Tan Hill is about the best bit.chopper602 wrote:So are you doing the full run from Leeds or just meeting up with them at Tan Hill or Hawes?Citroenmad wrote: Two weeks yesterday is the 2cvGB Raid Tan Hill event, which I will be attending in the Beachcomber. Ought to be after all these hours on the seats, dash and carb
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
chopper602
- x 7
I don't know what I'm doing yet - might take the 'other' car and meet up there (you can order your food before the hoards arrive that way!)
Tim
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
Teesside
1985 Citroën 2CV6
2012 Toyota GT86
