sorry folks i have been trying to search but cant find anything so maybe i am doing it wrong?
basically i have to replace my turbo tomorrow as mines is done and was wondering if anyone had a good guide so i know exactly what i am up against, i know they are akward to get at, i just fitrted the engine too and its the turbo off my old engine i fitted to it whilst i had the engine out so i could see eaily but it was the first engine swap i had done in a 2.0 hdi berlingo and a guide for doing the turbo whilst engine is in would be great thanks
anyone have a berlingo 2.0 hdi turbo removal guide?
Lighty
- x 35
Re: anyone have a berlingo 2.0 hdi turbo removal guide?
I cant give you a complete guide tbh. Only done a couple over the years, and they are not easy.I think to be honest, i would remove the engine, and do all the other trickey jobs and be done with it, ie cambelt and clutch. Last one I did was a pug 306, and we dropped the front subframe, trouble is as they are old , lots of things are seized etc.
Takes the best part of a day if i remember correctly.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
fynnbar
ge0rge
i replaced all belts when engine was fitted also had a new clutch 3 months ago i also dont have an engine crane and near put my back out fitting the engine last week so im not overly keen on lifting it back out, the subframe in these doesnt really get in the way i suppose id be best just getting it up as high as i can and getting under there and check just how much i can see/get at
- x 2943
I don't know how much help this will be, there doesn't seem to be a listing specifically for the 2.0L HDI and I can't copy the images that the numbers refer to.
Remove :
The engine sub-frame (see the relevant operation)
The catalytic converter
The turbocharger inlet duct (2)
The turbocharger outlet duct (1)
The oil supply pipe (10) (on the engine)
The oil return (11) (on the turbocharger)
The nuts (6)
The screws (5)
The screws (4)
Retrieve the seal , at " a " .
Lift and release the EGR valve (7) .
Remove :
The 8 nuts (3) and their spacers
The exhaust gas manifold (8), the turbocharger (9)
Separate the turbocharger from the exhaust manifold .
2. Refitting
Proceed in the reverse order to removal .
Remove :
The nuts (6)
The screws (5)
The screws (4)
Remove :
2. Refitting
ge0rge
ive got sorted here im just about to fit the new one(tea break) for anyone looking this info in the future....
jack car up and support on ramps
take drivers side driveshaft out
remove rear engine/driveshaft mount
remove the few plastic pipes etc
then 3 11mm bolts hold the turbo onto the manifold...
no need for engine removal or subframe removal, dunno where that came from, for anyone else stuck and looking more info on it feel free to ask.
jgra1
- (Donor 2021)
- x 36
good to know it's quite straightforward, thanks George
John
John
- x 2943
On my C5 those three 11mm bolts to the manifold are Allen screws and they proved impossible to remove on the vehicle, had to get the manifold off and heat it with a blowtorch before they'd shift.
jaip
is this the same procedure then for the C5 2.0hdi?
