Where's the clock on this car
Where's the clock on the 03 C5 hdi?
stu9
- x 5
And what watt should they (3 bulbs) be, I know they're capless, I got 3 in Maplins the other day but they're very dim and you can hardly see it......but...
....it has got one I take it, is it suppose to be where the date ect is, if so how is it turned on
Citroenmad
- x 110
Re: Where's the clock on the 03 C5 hdi?
I'm not sure on watt of bulbs, I have just replaced like for like in the past but can't remember what they were now.m
The clock should always be visible ... So I'm not sure where yours is! It should be at the top right of the eventual display. Have you tried to set it in the menu? However, even in-set, it should still display
What spec is yours, LX?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
stu9
- x 5
Yes it's the LX
So i should see it, on mine just now, i've got the date (when the radio's off) and temp gauge, and the radio and temp gauge when driving, no sign of a clock.....i'll have a bugger about with tomorow
- x 1055
Do you have the original radio or an aftermarket one ?
Citroenmad
- x 110
The LX has a smaller display than the other trim levels, which might explain this. I've not been in an LX so I'm not sure how the display works. Do you press the end of the wiper stalk which cycles throug date and time?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
stu9
- x 5
@ wheeler.....the original......i know aftermarkets usually wipe a display off
@ citro.......i'll check it shortly
If this thing hasnt got one i'll be shocked, it's the first in years, i mean even my basic Astra 15 years ago had one!
Citroenmad
- x 110
All C5s had a clock from new, wether its working now is another thing
yes, try the button on the wiper stalk, i bet that'll bring the clock round ...
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
SaabC5
Clock is displayed top right of the info display centre dash, it should show even when you cycle through the options on the control stalk. An aftermarket radio makes no difference you only loose the radio/cd display not the time.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Citroenmad
- x 110
Not on an LX with smaller central screen it doesn't.SaabC5 wrote:Clock is displayed top right of the info display centre dash, it should show even when you cycle through the options on the control stalk.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
SaabC5
D'oh, didn't notice the LX bit.Citroenmad wrote:Not on an LX with smaller central screen it doesn't.SaabC5 wrote:Clock is displayed top right of the info display centre dash, it should show even when you cycle through the options on the control stalk.
stu9
- x 5
Yes when you press the end of the stock it's on the right side of the screen, it comes on with date and doesnt stay on, it goes back to the temp gauge
djjtl
You are having the temperature displayed permanently because of the current weather conditions.Mine is the same once it reaches a temperature of 4 degrees and above the time will be permanently displayed
03 C5 2.O HDi 90 LX Estate 97K
waynedance
- x 8
could he add the bigger display, is it plug and play? would the trip computer work?
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Citroenmad
- x 110
I've not looked into it properly as have never had an LX, however, I believe it does. There is a thread on here about fitting it, iirc, it's as simple as that.waynedance wrote:could he add the bigger display, is it plug and play? would the trip computer work?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
411514
- (Donor 2017)
- x 39
I remember with the xsara that it was possible to simply plug in the larger screen and it would work, id imagine its the same for the c5, samcould he add the bigger display, is it plug and play? would the trip computer work?
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
