As some of you will recall my bargain 01 C5 estate had a major vacuum leak as the spigot that the feed for the swirl valve connects too at the vacuum reserve had been sheared off, now I have blanked it off but this means there is no vacuum to the swirl valve actuator. I have to try and tee in somewhere to find a new feed for it in the mean time how long is it safe to run with out an active swirl valve? Will it just be a case of poor fuel consumption or will it do some harm? Has any one any ideas where I could tee into to get a vacuum back to it.?
Any suggestions greatly appreciated.
How long is it safe to run a c5 with swirl valve disabled
horsedentist
horsedentist
Re: How long is it safe to run a c5 with swirl valve disable
Any suggestions ?
SaabC5
Mine was broke when i got mine, i didn't notice it for at least 3 months and then took another month to get around to fixing it. Didn't seem to harm mine at all but mine was only running on 12 valves so underpowered.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1238
I don't think it makes any noticable difference to the performance - to the emisions perhaps.
horsedentist
Cheers lads will find out about the emissions dropping it off at the mot station later
cachaciero
- x 9
Wire the swirl valves shut and carry on, the engine normally runs on 12 Valves until 2300 rpm which is 70 on the motorway so you will hardly ever notice that they arn't opening. Could probably go on for ever in this state.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
horsedentist
Well it passed the omission test with flying colours.
Monkeyfeet
Hi.
Glad it passed. What exactly was missing? (sorry only joking
And wot Cachaciero said exactly:
I ran ours for a long while and many miles with valves wired shut and it went through MOTs no prob, don't think it would affect emissions anyway, though I stand to be corrected on that. Fuel conumption no worse either. With a new actuator it just meant that you could rev it more if you needed to. Certainly no damaged has occurred.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
