C5 Brake System Fault - STOP!!
corsehf
Unread post by corsehf »
The STOP warning light has now come on with 3 bleeps and a warning on the dash of a 'Brake System Fault'.
Is there a 'Sure Fire Reason' for this??
I have checked the front discs + pads and they are not that low - the friction material is now the same thickness as the plate but nowhere near the sensor - yet.
Any ideas?
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
x 1485
Re: C5 Brake System Fault - STOP!!
Low brake fluid level?
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Is the wiring to the sensors OK. If the covering gets chafed they can 'short' and ring up a warning.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1056
Unread post by wheeler »
Another quick check you can do is check your brake lights are operating correctly, if the lights are stuck on the ECU's will think your accelerating & braking at the same time & can throw up faults.
Is the ABS light on aswell ?
