Rear ram bush
x 8368
Re: Rear ram bush
Yep...
Rear high on stands. Suspension and Activa system de-pressurised...
Undo lower eye bolt in the Ram. I believe this is a 6mm Allen bolt but check.. This gives a useful guide to the preliminary work needed.
Then follow what it says here...
Note the use of mandrels. The remains of the old bush will generally be very tight in there.
x 8368
Re: Rear ram bush
superloopy wrote:Cheers Jim, its depressurising Activa side of things that scares me .... job on hold.
Strictly you don't need to Mike as over time it'll depresureise itself. Doing it makes it a bit easier to move the ram around but generally if you wait a few hours it'll have naturally depressurised itself enough for it not to be a problem...
x 8368
Re: Rear ram bush
superloopy wrote:So if I get her up on stands, plusgas up the bolts all should be well for the weekend ...
Yes, I'd say so Mike...
DickieG
Monaco's youngest playboy
x 38
Re: Rear ram bush
Unread post by DickieG »
Why? :? To depressurise the balancing side of the system push and pull the rods behind the front wheels until the car stops trying to respond to the rod movement, sorted, two minutes work.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8368
Re: Rear ram bush
Yep, that's another good way Richard :-D Completely forgot about that one :oops:
