charging fault
Robert12
charging fault
Hi just got in c5 2.2 estate and its come up on the dash saying charging fault and the pointer for the battery dropped to 0 . does this meen the alternator is nackerd ?
- x 1238
Re: charging fault
Connect a voltmeter across the battery, it should read about 14.4 volts with the engine running, much lower than this alternator probably u/s.
Robert12
Re: charging fault
Thanks for the reply peter just put meter on it and its showing 12volts with engine running so looks like I will have to get a new alternator
Onlinemyglaren
- x 5577
Re: charging fault
May just be a kippered diode in the rectifier, cheaper than a new alternator.
Robert12
Re: charging fault
Hi fitted new alternator and its still the same is there any fuses for the alternator?
Onlinemyglaren
- x 5577
Re: charging fault
Looking more like poor connections to the battery or earth.
Have the battery leads and terminals been checked for tightness and cracks?
Lighty
- x 35
Re: charging fault
Biggest issue on a C5 is oil leaking from the pump above, straight into the alternator. New clip on the pipe cures the leak before you destroy a new alternator
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Robert12
Re: charging fault
Theres no oil leeking from the pump above it seems ok
addo
- Sara Watson's Stalker
- x 95
Robert12
Re: charging fault
The battery seems ok with a load test ITs not dropping off
Robert12
Re: charging fault
The new alternator was faulty got it exchanged for another ,and all is ok
