Xantia Jack
Clogzz
x 40
Re: Xantia Jack
Unread post by Clogzz »
Went to see and it’s looking very good.
It’s got the original scissor jack with handle, and also the tow hook.
The wheel is steel and the tyre is a Michelin Energy 185/65/15 with plenty of tread, and still under pressure.
The date stamp is 2500, which is June 2000.
That’s supposed to be too old to use, but in Queensland we don’t know that. :|
I asked the guy if you could afford it, Image and he said to contact him.
Image Image
Sam KS
Re: Xantia Jack
Unread post by Sam KS »
Thanks Clogzz, but no need. he has emailed me his number (not ring me back, that's why i emailed him my number). I'll give him a call tomorrow and get my collogue to check and pick up the parts over the next week.
thinking of replacing the A/C switch (if he'll give it to me cheap) and the steering wheel (if it's cheep and has working controls). Any one know if the A/C switch (the one next to the hazard lights) is hard to replace?
Citroën Xantia 75th Anniversary Limited Edition
x 8423
Re: Xantia Jack
The A/C switch is only clipped in Sam. You're very best removing the switch panel to do it though. Not hard on an S2.
You want a nice leather steering wheel :wink:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
AC switch is dead easy to swap, but you need one off a Series 2 car as the plugs varied a bit. Use your 6" engineer's rule to gently prise out the switch's bottom edge, then the top edge.
Sam KS
Re: Xantia Jack
CitroJim wrote:You want a nice leather steering wheel :wink:
No, just the RH switches don't work for controlling the stereo.
x 8423
Re: Xantia Jack
More than likely cracks in the flexible printed circuit that links the switch bank to the connector Sam.
With care and patience it might be recoverable...
Sam KS
Re: Xantia Jack
CitroJim wrote:More than likely cracks in the flexible printed circuit that links the switch bank to the connector Sam.
it is. some ham fisted monkey has been in there and broken the connection (and tape)... problem is that ham fisted monkey was me. :oops:
x 8423
Re: Xantia Jack
Ahh...
addo
x 95
Cloggs: How was the carpet in that gold parts car?
I am seriously hanging out for series 2 front underfelt that's not been loaded with LHM from a leaky brake doseur.
Clogzz
x 40
Re: Xantia Jack
Couldn’t see anything inside the car, it was absolutely full of junk … a real dump … and possibly flood damage.
The engine and suspension must work because the car was parked on the high setting.
This guy depends entirely on eBay, that’s why I think he doesn’t make STD calls as per Sam’s post.
