C5 heater blower
Jerome3
C5 heater blower
Unread post by Jerome3 »
Hi my 02 c5 heater blower ain't working sometimes it works on full but most of time it doesn't work it's the a/c model not digital changed the resistor no change help!!
x 1240
Re: C5 heater blower
Unread post by Peter.N. »
If its the same as the one in the XM its likely that the speed regulator transistors have failed.
Jerome3
If this happens would it be on full or not at all have changed the resistor already
Jerome
x 1240
If it has resistors its not the same motor the XM one has transistors and failure gives a variety of faults, running flat out is one of them if the transistors go short circuit but they can also go intermittent causing erratic speed control.
Jerome3
Resistor transistor dunno it's green in passenger footwell
x 1240
Sounds different, the transistors are soldered onto a board actually in the motor assembly. I haven't had a problem with mine yet so not looked.
imperial21
Unread post by imperial21 »
C5 Heater resistor is on the leht hand side of the drivers side foot well you can see it if you remove the trim below the steering coloum and look left it has 2 small connectors.
looks like
http://www.ebay.co.uk/itm/221132479515? ... 1423.l2661" onclick="window.open(this.href);return false;
Apparently known for loose connections.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Jerome3
Is this not where the climate control model is found mine has just the a/c
Jerome
