Xantia clock
froggy
(Donor 2026)
x 4
Xantia clock
Unread post by froggy »
Hi, when I turn the ignition key off, the clock turns off as well. every time I start up, I need to reset the clock( irritating) Anyone got any ideas? cheers Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's an economy measure, to keep all those minutes inside the clock. Saves wasting time when you're not driving. :wink:
froggy
(Donor 2026)
x 4
Re: Xantia clock
Ha, Ha.
Terry
x 94
Re:
Unread post by citronut »
addo wrote:It's an economy measure, to keep all those minutes inside the clock. Saves wasting time when you're not driving. :wink:
:eye: :yikes: :teabag: T time i hope
:-D :-D :? :lol: :lol: :wink:
Regards, malcolm.
x 94
Re: Xantia clock
ps.
what should happen on turning the ignition off is just the clock back light goes out, but the clock should carry on tick tick tick ticking
Regards, malcolm.
froggy
(Donor 2026)
x 4
Re: Xantia clock
The digital display diappears when I turn off. when I start up, ...... 0000.
Terry
Chris570
x 36
Re: Xantia clock
Unread post by Chris570 »
is it mk1 or mk2? i know that on a mk2 you cannot adjust the time unless the ignition is on, so logically it has a switched live feed, if yours is a mk2 i would suspect it's lost it's constant live. (or is dead, like mine that resets itself randomly)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
froggy
(Donor 2026)
x 4
Re: Xantia clock
it"s a mk 1, cheers.
Terry
Chris570
x 36
Re: Xantia clock
on a mk1 do you have to have the ignition on to change the time though? if you do the theory could still be correct...
(if not go look in your fuse box as i've a sneaking suspicion that on the mk1 the radio and clock share a feed which could me a misplaced fuse could well be the cause)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8423
Re: Xantia clock
Or...
The shunt is in the 'showroom' position in the fusebox (if it's always done it). This was done at production and delivery time so the clock wouldn't flatten the battery.
Ensure all fuses are in the positions as in this picture... Note the position of the shunt (SH or even HS)#
froggy
(Donor 2026)
x 4
Re: Xantia clock
Thanks Jim, the picture is a great help.
Terry .
Terry
falling-out-with-my-car
x 25
Re: Xantia clock
Dont do what I did rip out half the dashboard to replace the clock backlight on my S2 I even checked it to se if it would light up, and when i put the dash back together it wouldnt light up anymore.Grrrrrrr.
