Citroen GS' spotted
Dedicated to owners of Citroen GS and GSA models.
macplaxton
Re: Citroën GS' spotted
Unread post by macplaxton »
myglaren wrote:Oddly enough I did hear, ages ago when I was driving a GS, that it was supposed to be the Princess but was rejected by BL and adopted by Citroën.
Probably a UL but innerestin.
Great piece of BS as even the dates don't really stack up :lol: Sounds just like the wrongly-remembered amalgam of several half-heard stories.
Most likely it was something to do with the similarity between the 1968 Pininfarina / BLMC 1100 and the GS.
The 1967 Pininfarina BMC-1800 Berlina-Aerodinamica is (the original bigger brother of the above) an interesting pre-CX thing. Other cars of the time of passing interest is the Maxi-based Aquila.
On a later note, the Triumph SD2 / Reliant FW11 / Volvo Tundra / Citroen BX
citronut wrote:that one looks like someone has over pumped the elastic suspension :shock:
It looks more to me that it's been pumped to the correct height.
Far too many Hydrosag cars going around low because all the nitrogen has gone on holiday in the top halves of the displacers. Most likely these are front ones and then the car has a nose down arse up stance. If any attempt to pump them up to the correct trim height (front hub to arch measurement) is made, then the suspension will either end up rock hard or burst.
x 94
Unread post by citronut »
it certainly looks far higher than i remember them
regards malcolm
Regards, malcolm.
x 5612
regards malcolm
Does rather, now you mention it.
ren16tx
Re: Citroen GS' spotted
Unread post by ren16tx »
the GS did attend a few uk citroen meetings, i remember seeing it at the G rally, wonderd where she had gone!!
macplaxton
I see now that it does have an export marker on the DVLA file.
