c5 auto head light problem
x 1480
Re: c5 auto head light problem
Haywire lights is often a sign that the COMS2000 is on its way out - this is the unit that the stalks are on behind the steering wheel. There are myriad different ones depending on the spec of the car, but as long as you get one that has at least the fitments you have it should be OK. If you have got ESP it needs to go on a Lexia after change to calibrate the steering angle sensor. Cruise (and radio control) unit just plugs into the side, so don't worry about getting that, just swap from yours to the 'new' one. AFAIK air bag, wheel and shrouds off then the unit can be removed.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
if you do go back Alan, could you grab me a small cruise brake light switch while you are there ?
cash waiting ;) no chance to get one myself and a long journey on sat..
dont worry if you cant. its a cheeky request
john
C5Alan
Unread post by C5Alan »
RichardW wrote:Haywire lights is often a sign that the COMS2000 is on its way out - this is the unit that the stalks are on behind the steering wheel. There are myriad different ones depending on the spec of the car, but as long as you get one that has at least the fitments you have it should be OK. If you have got ESP it needs to go on a Lexia after change to calibrate the steering angle sensor. Cruise (and radio control) unit just plugs into the side, so don't worry about getting that, just swap from yours to the 'new' one. AFAIK air bag, wheel and shrouds off then the unit can be removed.
Ok coms2000 is the stalks so the whole lot needs removed and replaced when you say the same fitment as mine I'm a little confused I don't want to pull my car apart just yet to check anything until I have something to swap it to. No esp so that's a positive. I. An see roughly how the lower shroud comes off 2 torx screws but air bag and steering wheel are a mystery will have a look in the Haynes manual when I get home. I have done stuff like thus to my old merc but this car just confuses me
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
C5Alan
jgra1 wrote:if you do go back Alan, could you grab me a small cruise brake light switch while you are there ?
john
That wouldn't be a prob John but I won't be back there till at least Friday got a horrible day at work tomorrow plus the car I was at didn't have cruise control. I'm happy to pull parts off and send them its half the point of these forums help each other out
jgra1
(Donor 2021)
x 36
thanks alan, no probs
I may pop to my nearest wrecker but its no biggy.
good luck with yours :)
C5Alan
right fitted a new 2nd hand comms unit today everything works except I cant get the auto lights to go on. I tried covering the sensor but nothing so have I bought a pup or could the prob be somewhere else? I dono if the flashing light problem is still there or not but will see over the next few days any help would be great
