Xantia outer tie rod emd ball joint
magictorch
Morning. Any tips on stopping the ball joint bolt from spinning when undoing the nut? I am replacing the steering rack boot on the O/S. I tried a g clamp, mould grips and cleaned up thread. All to no avail. Rain stopped play last night
- x 8450
Re: Xantia outer tie rod emd ball joint
Give the balljoint a big whack from the top with a big hammer to sit it back tight in its taper and then try doing the nut up a little. If that succeeds then carefully clean the exposed threads and soak in Plus-Gas. Undo the nut in a backwards and forwards action until it's off, whacking the balljoint top again if it should break out of its taper again.
In the past I've also cleaned up the end of the exposed thread by running a die nut up it. An ordinary nut will do the job too.
If all fails then try a nut splitter on the nut or if that fails it's a case of angle-grinding it off and replacing the track rod end...
- x 94
if what Jim says fails i use a long bar hooked under something solid at the sub frame end in such a way the bar also lays across the top of the swvel joint,
the bar needs to be long enough for you to sit on the outer end to add weight onto the swivel joint whilst undoing the nut
Regards, malcolm.
magictorch
Excellent. I will let you know how I get on.
Any advice for fighting the elements? Crickey its getting dark earlier and quicker.
- x 94
get one of those strap on ( no not that typemagictorch wrote:Excellent. I will let you know how I get on.
Regards, malcolm.
magictorch
These jobs are so easy when you know how!
Many thanks for the tip citronut
Edit: I used the 3 x 2" timber by proping it behing the disc but made sure it was clear of the CV boot.
- x 94
hope your not levering against the drive shaft
Regards, malcolm.
