Xantia wiring diagrams wanted please *Speedometer working!*
mirafioriman
Looking to find or see some Xantia wiring diagrams.
As part of my electronic speedo conversion I'm looking for a wiring diagram.
The sender unit and speedometer both only have three wires so it should be easy enough to wire up but I'd much rather see what wire goes where.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Timmy69
Re: Xantia wiring diagrams wanted please
Have you not got an Haynes Manual ?...if not i will try to take some pic's from mine and post them for you
Timmy
Timmy
mirafioriman
I've got a Haynes manual but I can't seem to see any wiring diagrams for the electronic speedo.
citroenxm
- Fallen Hero
- x 70
The haynes wireing diagrams are of useual "typical" cuircuits, and not dedicated ones, even though the FULL key is in the book!
I recall them NOT having the diagram with the electronic speedo printed, unless its combined into another cuircuit that has the Instrument panel in it.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Chris570
- x 36
the speed sensor is easy pin3 is pulse, you never know, you may find the other end on a dash plug
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
mirafioriman
Currently the centre pin of the speed sensor is earth. The two other pins on each side are currently dead at all times. I've tried plugging everything in and the speedo doesn't work so there is at least one wire missing somewhere
ihatecars
Although not a direct answer to the OP question. Interesting as I'm about to embark on fitting an electronic monitoring system to my Xantia to see if fitting hyrdogen is good option. My guess is like Chris570 says, a pulse, I will need to look closer. I also want to get access to the ECU to see what other info I can get. I'd like realtime info from the lambda sensor etc.
exect
Something worth thinking about, is the speed sensor actually producing pulses as it may not be just as simple as speedo cable out and sensor in.
Chris570
- x 36
if pin2 is earth it must be this way round....
pin1 switched 12v
pin2 earth
pin3 speed pulse to clocks/ecu
if you run a continuity test from pin3 to the clock plugs you'll probably find it
pin1 switched 12v
pin2 earth
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
mirafioriman
Thanks for everyones help so far
Would still like to see a wiring diagram if possible I'm interested to see exactly how it is wired up. For example does the power to the speed sensor come from the dash cluster or somewhere else etc.
Could someone with a working electronic speedo (for example on a car they are breaking for spares) test the speed sensor multiplug to verify what comes from each terminal? I'm going to look at my 'spare' electronic speedo dash now to see where the three wires that go to the speedo head end up on the dash cluster multi plugs.
mirafioriman
Been looking at the dash tonight. It looks like one of the three wires to the speedo goes to the fifth pin from the left on the red connector block. This could be the trigger wire perhaps. Need to check my loom next to see if there is a wire there.
Lighty
- x 34
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
mirafioriman
Teasing me or what?
mirafioriman
Re: Xantia wiring diagrams wanted please *Eureka moment*
http://www.ebay.co.uk/itm/Citroen-Xanti ... 0760932275
I know where this is located on the xantia as I found the multi plug to it and disconnected it on the scrapyard car I got the transducer from. I bet my Xantia has the plug but not the unit
Back to the yard to get it at the weekend
- x 8427
Umm, I'll check but I've never been aware of any Xantia having such a device. I may be wrong but I believe the item in that ebay ad is in fact the Bitron Controller for the cooling fans on A/C equipped cars... It lives under the N/S headlight.
I'll dig out the wiring diagrams later.
