Workshop Manual
Sam KS
Workshop Manual
any on know where i can get hold of a workshop manual for a 1998 Citroen Xantia 2.0 twin cam?
Citroën Xantia 75th Anniversary Limited Edition
- x 8309
Re: Workshop Manual
Haynes do one, commonly known as the BoL or Book of Lies around these parts. It has it's good bits but generally this forum is a much better manual...
Xantia BoLs are frequent occurrences on ebay for very small money. That's likely the best method of procuring one..
There are the factory manuals which a very few on here have but they're at least seven volumes, weigh as much as an ocean liner and take up a whole bookshelf. They're rare too.
However, anything specific you need from them I'm sure it can be provided
Sam KS
Re: Workshop Manual
the hanes one dose not cover the SVX 2.0 petrol. is this the 2.0 twin cam in the 1998 Xantia 2?
addo
- Sara Watson's Stalker
- x 95
The BOL can be bad to own. Sometimes it's plain wrong (like the 405 manual's torque settings for cam caps), other times they make hard work of a simple task, on yet further occasions they neglect important details of a protracted repair process.
Their wiring diagrams are so off at times, it's terrifying.
If you must, buy the 3082. It probably covers much of what you need, barring the 16V motor. It's also common as muck and you'll pay more for postage than the book itself costs in used condition.
Learn a bit of French and you can trawl the foreign language forums as well. Pretty much every Xantia escapade has been documented by someone, somewhere.
Sam KS
Re: Workshop Manual
Thanks, i also have a mate who is the after service manager at a le froggy dealership with over 15 years spinning spanners on them. even his spanners smell of garlic. he is going to email me the cam belt section of the OE BOL. i just didn't want to be bothering you all here or him with every noise on the thing.
also he is to far away and on the wrong contaminant to be able to help with things.
- x 8309
Re:
That's a good idea Adam. There there's the Revue Technique (French BoLs) that may be useful. Of the ones I've seen they knock Haynes into a cocked hat... My French is too limited to make a definite assessment of their value though...addo wrote: Learn a bit of French and you can trawl the foreign language forums as well. Pretty much every Xantia escapade has been documented by someone, somewhere.
addo
- x 95
addo
- x 95
- x 8309
Re: Workshop Manual
Even better
Is that to be carried out at the beginning of a procedure, at the end or at the point you realise the BoL is living up to its name?
addo
- x 95
- x 8309
Re:
Yea, that'll be rightaddo wrote: North of Capricorn, anytime you are awake and feel like it.
No doubt you in QLD will agree Sam?
Sam KS
addo
- x 95
Sam KS
Re:
as long as it's not that beer flavoured cordial p**s they drink around here. they cant even spell beer properly, they spell it xxxx.addo wrote:As in, cracking a tube of beer.
since moving to QLD i have had to start drinking John Smiths or Bodingtons.
