c5 2.0 hdi vtr 2003
i think i have read somewhere that to fit cruise all you have to do is fit the colum switch and 4 wire brake switch and activate on a lexia is this right or am i imagining it.
c5 cruise control
oneday
c5 cruise control
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Lighty
- x 35
Re: c5 cruise control
Not sure about the brake light switch, I always manage to just activate it.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
oneday
that sounds good just thought its a manual will the clutch need a switch
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 5652
Sometimes both the additional brake light switch and the clutch switch are there and all that is needed is the the stalk and a Lexia to tell the ECUs that it is present.oneday wrote:that sounds good just thought its a manual will the clutch need a switch
YMMV
oneday
will these be at the back of the passenger glove box.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
jgra1
- (Donor 2021)
- x 36
yes they should be..
I tried fitting to mine recently.. but I only have a single brake swtich.. am trying to get the switches I need.. have stalk in already but it's not working yet...
oneday
loads of switches oc ebay at a reasonable price
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
oneday
are all cruise control stalks the same and how much would you expect to pay for one.
does anyone have the part number
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Citroenmad
- x 110
Yours being a 2003 might have the second brake light switch. I fitted cruise to my previous C5, a 2004 2.0HDi VTR, which had the switch already fitted. All I did was get a cruise stalk, cut the notch in the column surround and enable the cruise function in the two menus with a Lexia.
Im not sure of the part number, however I think mine was around £30.
The cruise stalk for the earlier C5 is different from the C5II. You want the one which says on/off, rather than the one which says speed limiter/cruise control. Apparently the newer one will work (without the limiter function), but im really not sure of this, your best to get the correct one.
Edit: I must have been asleep, what with all those typos!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
oneday
thanks for your help very informative
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 1480
MK1 part number is 6242 Z9, Mk2 is 6242 Z8 Cit prices are £55 for Mk1 and £65 for Mk2. This one on the bay would appear to be the right one.
Citroenmad
- x 110
That is more than I remember mine being, it was over two years ago though.
I would start with the stalk and using a lexia to set the cruise. If it doesnt work you'll need a second brake switch, but you wont need to enable the cruise again once fitted.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
jgra1
- (Donor 2021)
- x 36
Chris, can you remember where the two lex options are? Jim and I could only find one place to enable...
oneday
thanks for all your help i can get started on this project now
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Citroenmad
- x 110
There is certainly one in the injector menu, which is the one which had me stuck originally as I didnt think to look in there.
The other is in the BSi menu, I think!
There is definitely two, which might explain why yours is not working yet
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
