Cit part number - what does this fit?
andmcit
x 30
Unread post by andmcit »
I have a few speed senders I've acquired as part of a set job lot from a Cit dealer but cannot
reference them. Part number is 5 MA 95 494 865.
Any ideas?
Nothing moves you like a Citroën
x 695
Re: Cit part number - what does this fit?
Unread post by Mandrake »
Gearbox speed senders ? I guess you have no idea what model they're from ? I'm sure the Citroen service info I have will list them, but there doesn't seem to be a way to do a reverse search on a part number back to a model...
x 695
Xantia, C5 and Xsara all list part number 6160 70 for the speed sender, checking through a few others as well. Are you sure that's the right number of digits ?
x 94
Unread post by citronut »
Mandrake wrote: but there doesn't seem to be a way to do a reverse search on a part number back to a model...
you can do an all families search but you have to switch off the filter,
5 MA 95 494 865 comes back as no parts found on service citroen
i belive the MA relates to an older citroen part but cant remember which model it relates to
but i know a man who will ( Malcolm Lockwood would/will )
Regards, malcolm.
x 695
I searched for speed sensor on most of the models from BX onwards, there are only about 3 or 4 different part numbers across all the models I checked, none with that many digits, so I'm drawing a blank.
x 1060
Unread post by wheeler »
Where are you getting the part number from ? Citroen part numbers are usually only on the bag or box the part comes in , not on the part itself. Most citroen part numbers are only 5 digits but you can get them with longer numbers.
miked
x 6
Unread post by miked »
Just a guess but the MA could mean it's for a MA gearbox, as fitted to TU engines (AX / Saxo etc).
x 94
miked wrote:Just a guess but the MA could mean it's for a MA gearbox, as fitted to TU engines (AX / Saxo etc).
or a Maserati/SM
Regards, malcolm.
handyman
Unread post by handyman »
Hi Andrew, Citroen list it as a speed sensor ( #-o ) but as its an early part number 95 code, it wont appear in the current schedule with Servis Citroen. Lucky to still get some of the 96 codings still showing! :shock: That coding 95, is pre Mk2 CX, so might be GSA, Mk1 CX or even DS! No not the new ones! :roll:
Mr Malc is right though, that font of all knowledge Citroen part numbers should know, Mr Lockwood of Bradfordabad.
BTW, knock off the 5MA prefix.
Handyman
