It may not need enabling on a lexia ala C5. If it was a simple, if the switch is fitted it works system which given the age of car is possible. Citroen could so easily have done a lot of different things to the Xantias but for whatever reason didnt, a trip computer for one. The wiring is a trivial thing really though....CitroJim wrote:True enough Chris but show me on the Lexia where you may enable it. I've not seen it. Also, I'm not aware the HDi has the wiring in place for the column stalk. I'm sure we've been here beforeChris570 wrote:IF the xantia has it then there is no reason that i can see that it cannot be added. (i'm not talking about a legal standpoint here either.)![]()
If it were possible I would have thought Citroën might have offered it as an option on the Exclusive HDi. As far as I know they didn't. This would have been the only one as apart from the 2.1TD (IIRC) that had a throttle pot rather than a direct bowden cable to the throttle butterfly or load lever as appropriate.
Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
Chris570
- x 36
Re: Lexia or KWP2000? Retro fitting Cruise Control on a Xant
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8423
OK, put your money where your mouth isChris570 wrote: It may not need enabling on a lexia ala C5. If it was a simple, if the switch is fitted it works system which given the age of car is possible. Citroën could so easily have done a lot of different things to the Xantias but for whatever reason didnt, a trip computer for one. The wiring is a trivial thing really though....
PIT
Take a look
" onclick="window.open(this.href);return false;
"Regulateur de vitesse" = Crouse control
There is a man in a Spanish Xantia forum who installed Cruise Control on HDI.
I'm going to follow his work to do it on my Xantia.
There are a few versions of the ECU. The early ones doesn't have any options to configure something. The newer have a Configuration menu ("Telecodage" in the video) where it can be programed.
Tomorrow the 2001 Xantia ECU will arrive. It should be the correct one. On Saturday I'll take a stalk and ON/OFF button from petrol Xantia with auto gearbox and cruise control.
If everything is OK, at the end of the weekend I will have it working.
Then I can provide you a full "How to" if you do not want to read it in Spanish
The Spanish forum is http://www.clubxantia.com/" onclick="window.open(this.href);return false;
You need a registration to view their "Do it yourself" forum which is called "Bricos"
The thread is called "Instalación regulador velocidad motor HDi". Direct link - http://www.clubxantia.com/viewtopic.php?t=11451" onclick="window.open(this.href);return false;
And btw a trip computer can also be installed on almost all Xantia ECU-s. They have an enabled pin for current fuel consumption that gives information to the trip computer.
This is from 406 (the old one without BSI) http://postimage.org/image/64thhzn0z/" onclick="window.open(this.href);return false;
measuring also an internal temperature, with a sensor next to the AC sensor
http://postimage.org/image/8zvynoan3/" onclick="window.open(this.href);return false;
PIT
The HDI Xantia have wiring for CC stalk and button but it is not going to the ECU. The ECU pins are empty...
But I found one big connector between the front seats which is for the CC module used in petrol models.
So all wiring should be made by yourself
- x 1473
On a Xantia, where does the distance signal get connected?PIT wrote: And btw a trip computer can also be installed on almost all Xantia ECU-s. They have an enabled pin for current fuel consumption that gives information to the trip computer.
measuring also an internal temperature, with a sensor next to the AC sensorhttp://postimage.org/image/8zvynoan3/" onclick="window.open(this.href);return false;
Did you find a wiper switch with trip button that fits a Xantia?
PIT
The trip computer from 406 D8 and also on XM uses signal from the speed sensor which is the same - 8 pulses per tire revolution/5 pulses per meter.
This is the schematic for 406 - http://postimage.org/image/2h38cr344/" onclick="window.open(this.href);return false;
1620 is the speed sensor. 1625 is not mandatory. We don't have it. I took the speed signal from the dashboard with the fuel level signal and low fuel telltale signal.
The stalks are the same on 406 and Xantia. But we have the rear window heater button on our wiper switch. So I used lights/indicators switch with horn button on it, like on Xantia 1(96-97 with fog lights on it), Xsara, and others...
- x 8423
PIT, this is getting most interesting
Have you made the cruise work on your Activa?
PIT
PIT wrote:Tomorrow the 2001 Xantia ECU will arrive. It should be the correct one. On Saturday I'll take a stalk and ON/OFF button from petrol Xantia with auto gearbox and cruise control.
- x 1473
If I can find a mfd from an early 406, I will try connecting it in my Xantia S1 V6, which does not have the window heater button on the wiper switch.PIT wrote:The trip computer from 406 D8 and also on XM uses signal from the speed sensor which is the same - 8 pulses per tire revolution/5 pulses per meter.
Looking at the 406 schematic, I think that the connections top plug:
1. battery feed
2. ground
3. accessory feed
4. ignition feed
5. illumination feed
6. thermistor (door mirror, or interior)
7. thermistor (door mirror, or interior)
9. radio bus (not used)
10. radio bus (not used)
13. fuel gauge (from instruments)
14. fuel gauge (not used)
15. radio bus (not used)
bottom plug:
2. ground
5. mode switch (wiper stalk, or other)
6. fuel warning light (from instruments)
10. VSS signal (from speedo)
12. Injection signal (from ECU )
I have 2 marked as fuel warning, but one must be for something else?
Which model radios was this compatible with for radio display? any Blaupunkt?
Is miles/kilometers gallons/litres switching is chard coded.
[edited with corrections]
PIT
It looks that the dashboard and the trip computer are connected in series to the fuel sensor, but in fact they are in parallel, because pin 13 and 14 are shorted on the PCB.
Pin 6 on the next line is from the low fuel light.
For your engine the pin for trip computer is 32.
MPG or l/100km is hard coded to the LCD. There is a possibility to switch between Celsius and Fahrenheit.
I need to check for the name of the 1625.
EDIT:
1625 - this is called Vehicle speed interface module
You can see it here:
http://peugeot.mainspot.net/wiring406/index.shtml" onclick="window.open(this.href);return false;
EDIT:
PIT
By the way I already have the new ECU
It is from April 2000. The ORGA number of the car is 8563. It is the correct one with "Configuration" menu with option for Cruise Control
As I know the ECUs with this version are fitted in cars after ORGA 8421.
Tomorrow I will wire all things and hope to get the stalk and the button
citroenxm
- Fallen Hero
- x 70
Wow.. i do soo much dual carrage driving i Will follow up getting cruise in my hdi 110 xantia too... i have the stalks.. same as XM stalks.. would just need a cruise switch for the dash...
watching closely..
watching closely..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1473
On the Xantia, is the low fuel warning signal available on a connector, or do I need to connect to the bulb holder?PIT wrote:It looks that the dashboard and the trip computer are connected in series to the fuel sensor, but in fact they are in parallel, because pin 13 and 14 are shorted on the PCB.
PIT
citroenxm
- Fallen Hero
- x 70
PIT..
Does the Trip Computer actually work?? If so what exactley have you done to get it working?? Id Very hapilly get rid of my ash tray for the fitting of that display... What wireing etc and bits need to be installed.
If I can do the same and get a Trip and Cruise working on this HDi Xantia of ours, Id love it again for about 6 months...
Watching closely...
Watching closely...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
