pipe clips
froggy
(Donor 2026)
x 4
pipe clips
Unread post by froggy »
Hi, on my 1997 Xantia, I have got these very infuriating pipe clips ( not jubilee clips) I have managed to undo one with a scriber but I am unable to clip back together! is there a special pair of pliers or a "knack" of clipping them back together? worst case , I will replace with good old jubilee clips, but I was hoping to keep the same clips. any ideas ? cheers Terry . :oops:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8365
Re: pipe clips
Yes, there is a special tool for them and it makes them infinitely re-usable... Laser make such a tool and they are/were available from Halfrauds. I can't right now but later I can supply the full details of the instrument you need.
Meanwhile, it's often possible to clip them back together using a pair of wire-cutters. The knack is to get thin blades under the clip part and wire cutrters can do that quite well with practice. No substitute for the pukka tool though...
froggy
(Donor 2026)
x 4
Re: pipe clips
thanks Jim, I"ll wait for the info.
Terry
x 8365
Re: pipe clips
froggy wrote:thanks Jim, I"ll wait for the info.
Remind me if I forget Terry :wink: My memory is not what it was :twisted:
spider
x 77
Re: pipe clips
Unread post by spider »
I have the proper tool, although its good its not 100% by any means, sometimes they won't go back together.
Sidecutters do work very well though, used to use these myself for these kind of clips.
Andy.
x 2941
Re: pipe clips
Carpenter's pincers work fine too, or even ordinary pliers with a bit of treatment on the grindstone :)
x 94
Re: pipe clips
Unread post by citronut »
i use carpenters pincers but with the inside face's of the jaws ground to a sharper profile, work as well on strut/leg retun pipe clips
Regards, malcolm.
HDI
x 7
Re: pipe clips
Unread post by HDI »
This is what you need, http://www.ebay.co.uk/itm/HOSE-CLIP-PLI ... 3a76b0c3db" onclick="window.open(this.href);return false;
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
wotwot
(Donor 2021)
x 4
Re: pipe clips
Unread post by wotwot »
Buy a pair of snipe nose pliers from the £ shop take them over the grinder without getting them too hot and you have a cheap pair of useful pliers.
