I have purchased a Xantia estate, getting it next week, and saved it from the breakers, due to a leak from the pressure regulator. I normally used to change these, but they are getting pricey.
Anyone know the part no of the seal kit , to fix it, the repair looks simple, as I can use the press to strip it.
Xantia front accumulator housing leak
Lighty
- x 34
Re: Xantia front accumulator housing leak
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 8411
Martin's not really into websites... He advertises in the Citroenian and by word of mouth and communicates best by 'phone or visit.rpaco wrote:The only website I could find was a single pdf document and it still has only the old address
Lighty, he'll have the bits you need to fix the pressure regulator...
Lighty
- x 34
Thanks, I didn't know if Citroen still sold them.CitroJim wrote:Martin's not really into websites... He advertises in the Citroenian and by word of mouth and communicates best by 'phone or visit.rpaco wrote:The only website I could find was a single pdf document and it still has only the old address
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
rangi01
- New User
Deanxm and the rest who have posted here, THANKYOU sooo much
. This really helped me.
Just wanted to add, if you don't have a big vice you can, with some care, use a cheap F clamp (less than $7.00). I didn't want to remove the sphere as I had only recently changed it, so got a 400mm F clamp
Worked a treat and no more green blood on the garage floor
- x 94
i think it would also pay to fit a shake proof/spicky washer in between the end mounting bracket and the reg end cap,
this should make sure the end cap does not turn while tightening up the mounting bolt,
Regards, malcolm.
Jaf
- x 42
So do I get a prize for the longest time taken to repair something/ laziest person?! Finally got round to fixing the regulator leak after 2 years! Whee!
Big thanks to deanxm for piccys, was very straightforward.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 8411
Well done Jaf! Very good work!
That's an LHM leak too but one that only happens in the winter... hence why it's not been done yet!
No, I have an outstanding job on my Activa that's been waiting for over two years nowJaf wrote:So do I get a prize for the longest time taken to repair something/ laziest person?!
romie
Re:
Heya, great work, nice detail and very useful!citroenxm wrote:Ah ha.. My dealer could not find an exploded diagram of the regulator...
Does anyone know the part no for the one that sits in the plastic return part at the bottom of the regulator.... ??? I need a few of these too.....???
paul
So for the bottom seal that goes in the plastic bit in the bottom, did anyone get sizes/part numbers in the end for that?
(are these two parts the seals for the the bottom plastic bit of that pressure regulator?)
Many thanks, romie
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
Yamaha R1 1999 26k
romie
Re:
Fantastic, only do you know the size of the o ring that you used from that pack?Deanxm wrote:Here you go Paul cheaper than anything you will find at the dealer and always to hand
Having said that my set didnt have a seal that would fit the bottom plug of the reguylator as that is rather chunky but there are ones that can be used in place of the one used on the plastic return housing, the original i flat like a sphere seal but an o ring works a treat, especialy when you cant get the original and you have a leak.
D
Many thanks if you can figure that out.
And just to confirm the procedure, I just need to:
Lower, depressurise, remove plastic bit (being careful due to spring), insert new seals, screw plastic bit back up against spring, and job done?
I see the end cap seal is more work.
The pressure regulator is leaking in both the end seal where its bracket is mounted and it's also leaking between the plastic bit and the main body.
I'll be checking this post out in detail for the end seal change!
Cheers, romie
Yamaha R1 1999 26k
Yamaha R1 1999 26k
