Bolts and fixings
froggy
(Donor 2026)
x 4
Bolts and fixings
Unread post by froggy »
Hi, I have just changed the Auxcillary belt on my 1997 Xantia, While doing the job, I needed to remove the plastic gaurds to acess the belt. What type of bolts and fixings hold the gaurds to the car. Mine are totally coroded and unuseable. would these bolts and fixings be a dealership only product ( whatever they are called) thanks Terry . p.s. they have a 10 m/m head.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
citroenxm
Fallen Hero
x 70
Re: Bolts and fixings
Unread post by citroenxm »
Guards on a TD Pump... Dont think we ever got those here in the UK...
We did however on some Petrol Models... but Ive never seen a TD pump with a guard... :?
A very sad...
1994 XM 2.1 d auto
x 8321
citroenxm wrote: We did however on some Petrol Models...
The Activa with the TCT engine is one although few still have them...
citroenxm
Fallen Hero
x 70
And i do have a cover for one of the petrol engines with air con setup.. came off a 1.8i 8v petrol.. i kept it too.. just incase.
but as for a td... still never seen a td with one...
A very sad...
1994 XM 2.1 d auto
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
guys, i think he's refering to the wheel arch guards, 10mm bolts that go into those clip on nuts (captive nuts??) that Always rust and sieze in place!!
'58 C2 Code
'58 partner teepee outdoor
x 8321
Timmo wrote:guys, i think he's refering to the wheel arch guards, 10mm bolts that go into those clip on nuts (captive nuts??) that Always rust and sieze in place!!
Yep, that sounds like it Timmo...
I will have a butchers in Service.Citroen and see if I can find them...
Those shields are very important to protect the belt and pulleys from flying stones...
x 8321
There we go...
Items 72 (Self Tap Screw) and Item 74 (Speed Nut) is what you need...
citroenxm
Fallen Hero
x 70
And also stop the eccentric tensioner bearing from drying up from water splashes...
doh how stupid of me to assume pump cover :oops: :oops: :?
I see what were talking about now...
A very sad...
1994 XM 2.1 d auto
froggy
(Donor 2026)
x 4
cheers Jim
Terry
