I have a old coded immboilers in my xantia. There doesnt seem to be any pattern. For when i need to put the code in againe. For example went in a petrol station. For a couple of mins in and out. Needed to re code it. Then went in to a shop evern longer. And i didnt have to recode it. Its wierd.
Has anyone experiance this
coded immbolisers citroren and pugeote
spider
- x 77
Re: coded immbolisers citroren and pugeote
What do you mean ?
You will need to enter your code when it goes back to red...
Its possible on most models to set them to go to "green" when you unlock with the remote, however you only have 30 seconds to switch the ignition on before it goes red again.
If its switching between numbers ( ! ) perhaps its in service mode and is using that code and / or you are setting the "service mode" code...
Need more specifics really.
If its not set for the 30 second delay (only works with remote not door key) then its:
red light flashing
ignition on
red light (not flashing)
enter code
green light
red light flashing
ignition on
enter code
green light
Andy.
citroenxm
- Fallen Hero
- x 70
Interesting that!
I "Woke" my V6 SEi XM up on Saturday from a years rest.. connected the battery.. ignition on, and to my surprise the Keypad was on green!!
After battleing with a lazy starter due to a not so healthy battery on the car normal service was resumed in that I had to enter the code after the key was off for a moment or two...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
R9UKE
- x 3
Starting a V6 XM after a year of hibernation.... these are the kinds of things I dream of.
French is best.
citroenxm
- Fallen Hero
- x 70
She is also on offer as a project like my v6.Xantia... but i have everything to do the xm except spheres... have a look on club-xm.co.uk
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
spider
- x 77
I guess you could always just unplug it when its at green if it annoys too much.
Actually if its resetting itself that might not be a bad idea temporarily to try to see if it still locks without the keypad, which would point to a fault in the ECU and / or CPH unit but that seems a bit far fetched...
Andy.
jacksun1987
ive only been using the key. Becase i havernt got a remote.
spider
- x 77
That's normal then. After about 30 seconds or so with the ignition switched off, it will go back to wanting the code being entered each time.
The code number should not be changing though, is that what's happening ?
Andy.
OnlineCitroJim
- x 8287
spider wrote:That's normal then. After about 30 seconds or so with the ignition switched off, it will go back to wanting the code being entered each time.
Absolutely, yes. However...
If you stay in the car (i.e. don't open the doors) but do switch off the ignition the 30s no longer applies and you'll find it green when you next switch on the ignition however long you've waited so door opening and closing also has something to do with it...
If the keypad never sees the door signals for whatever reason that might account for it...
jacksun1987
what im trying to say is some times i get out of the car for a long time. And i dont have to put the code in. Others sems a short time and i d have to put the code in.
Its got a mind of its own
spider
- x 77
May well be the door signal then as Jim pointed out. I'll confess I'd not really even thought about those, was not aware all keypad equipped models used them.
Open / close each door in turn a couple of times (including hatch) and watch the interior lighting / hatch light etc to confirm they do always work or always not work, an intermittent one may well be the cause of its randomness.
Andy.
Northern_Mike
Not sure about you lot, but I find the keypad immobilisers an annoyance. No one is going to nick an S1 Xantia these days anyway. I'm so glad the one on RUNN has been disabled! Now I just want a coin tray then I can dispose of the thing altogether and actually use the space it takes up..
Xaccers
- x 186
Exactly, start the engine, unplug the keypad, fit an oddments tray, inform insurance and don't let them charge you any more.Activa_Mike wrote:Not sure about you lot, but I find the keypad immobilisers an annoyance. No one is going to nick an S1 Xantia these days anyway. I'm so glad the one on RUNN has been disabled! Now I just want a coin tray then I can dispose of the thing altogether and actually use the space it takes up..
DIY sphere tool
DIY sphere tool
citroenxm
- Fallen Hero
- x 70
ive done this on the v6 xantia project ive got in...Activa_Mike wrote:Not sure about you lot, but I find the keypad immobilisers an annoyance. No one is going to nick an S1 Xantia these days anyway. I'm so glad the one on RUNN has been disabled! Now I just want a coin tray then I can dispose of the thing altogether and actually use the space it takes up..
ive also a couple of oddment trays too kicking about...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
