all locks just spin
john
all locks just spin
Unread post by john »
hi, i cant use the key to lock either the doors or the boot on my newly acquired mk1 berlingo, all the key does is just spin, on the drivers door it feels "notchy", ive had a look inside the passenger side and it looks ok, can also see a couple of wires going into a box which i guess is the central locking? if thats the case when i push 1 of the door pins shouldn't all doors lock?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 94
Re: all locks just spin
Unread post by citronut »
try pushing the key in hard as you turn it, this worked on my XANT when it did it,
with the dentral locking try pushing one of the fron door lock buttons down with the doors shut,
regards malcolm
john
citronut wrote:with the dentral locking try pushing one of the fron door lock buttons down with the doors shut,
regards malcolm
tried that, only locked the door i pushed the pin on :(
i find it really strange that all the locks spin, 1 is unlucky, 2 is bad luck but 3?
Subaru Impreza WRX
Nissan Primastar
Stekelly
Unread post by Stekelly »
The barells on the Berlingo/Partner and Dispatch/Expert spin when you dont push the key right. Not to say yours arnt just borked but They need a small amount of pressure to turn right. Try inserting th ekey in the other way up too.
john
i think they're buggered, dont matter how hard i press they just turn :(
Subaru Impreza WRX
Nissan Primastar
Lighty
x 34
Unread post by Lighty »
I just fitted a new random lock on a Berlingo today, £75 + vat from Citroen. #-o
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
john
yeah them aint cheap, valeo (think thats how you spell it) also sell complete lock kits.
Subaru Impreza WRX
Nissan Primastar
Xaccers
x 188
Unread post by Xaccers »
Surely if it's all locks then the key is most likely to be worn not the locks?
DIY sphere tool
x 5673
Or the wrong key?
Xaccers
x 188
myglaren wrote:Or the wrong key?
There's a thought, ignition barrel could have been replaced, and if a previous owner always used the remote central locking then they'd not need to keep the door keys with them.
DIY sphere tool
john
if it was the wrong key or a worn key would the lock still turn?
the key works ok on the filler cap and glove box but i have to jiggle it a bit to unlock the steering lock.
Subaru Impreza WRX
Nissan Primastar
Xaccers
x 188
john wrote:if it was the wrong key or a worn key would the lock still turn?
Wrong key would just spin, but as it fits the filler cap and glove box then it doesn't sound like it's the wrong key.
Could just be worn, don't suppose it came with a spare?
DIY sphere tool
john
Xac wrote:don't suppose it came with a spare?
it did, but that does the same though :roll:
Subaru Impreza WRX
Nissan Primastar
Old-Guy
x 26
Unread post by Old-Guy »
Probably the pins in the door lock barrels have got stuck with muck and corrosion; the pin springs should make the pins follow the serrations on the key. Try a good work-out with plenty WD40 - squirt in the lock, run the key in and out; repeat until you can feel the pins running over the key serrations. Wipe the key really thoroughly before you fold it back into the plipper! :shock:
john
Old-Guy wrote:repeat until you can feel the pins running over the key serrations.
have to admit i cant feel any serrations
Old-Guy wrote:Wipe the key really thoroughly before you fold it back into the plipper! :shock:
havne't got a flip key, just one of those old fashioned jobbies :-$
Subaru Impreza WRX
Nissan Primastar
