My XM V6 ES9
citroenxm
Fallen Hero
x 70
Re: My XM V6.... She Lives! Come look, BIG update....
Unread post by citroenxm »
red_dwarfers wrote:Teves and ATE are one and the same. The sensor I bought for mine (Mk4) was around the same for the genuine ATE jobbie from GSF. Quite good really as I originally thought that ABS sensors were a nightmare to get hold of for the XM.
s1 xm and early s2 to early n reg are kev as they are bendix. those are the hard to get ones.. but s2 n reg onwards use tevis as per series ONE xantias.. sensors with the metal house on them
A very sad...
1994 XM 2.1 d auto
red_dwarfers
x 58
Unread post by red_dwarfers »
Ah, I thought I must have picked up that idea from somewhere, cheers Paul!
Kev
'19 C4 Cactus 130 Flair
Chris570
x 36
Unread post by Chris570 »
OK, wipers and ABS Sensors ordered, they are listed under that reg so hopefully they'll fit AND work ;)
Strut tops are coming off this weekend (if i can find the time) and will be sent to our lovely man in Lithuania for repair :)
Then just the engine oil leak to go, and again if i can find the time the inlet and belts will be coming off this sunday as well.
Once i've done that (10 min job max :O ) it's bumper on and off for a lovely MOT.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
red_dwarfers
x 58
Not much left then! It'll be good to see it back wafting its way along the road once more!
Kev
x 8353
red_dwarfers wrote:Not much left then! It'll be good to see it back wafting its way along the road once more!
Indeed to goodness yes :-D A real Pheonix arising from the ashes this one....
DHallworth
x 167
Unread post by DHallworth »
Chris,
I've not forgotten about those parts yet, this is my last week working away for a while so I'll deal with it on Monday.
You've got a lot more patience with the car then I'd of had.... I've got a feeling it'd of been broken for spares a long time ago if it were me that was doing the work!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Chris570
x 36
Ah excellent :)
Out of interest was there any installation instructions for the LPG (it's dead at the moment)
The car has been so so so close to being broken about 6 times now it loves to push it's luck.
I do feel now like i'm getting near the end now as there are less and less things to sort.
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
DHallworth
x 167
Off the top of my head I can't remember.
If you google the make on the LPG ECU you should be able to find them, I've managed this for the 2 Range Rover's we've got on LPG.
D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Chris570
x 36
Found a wiring diagram so hopefully all will be well.
I've just had an offer i couldn't refuse so the XM is now insured from the 1st July!!!
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Chris570
x 36
admiral multicar, they halved the cost of renewal of the activa and then mirrored my NCB from the diesel (7years) so it worked out that insuring the HDi, Activa and XM worked out cheaper than insuring just the HDi and Activa
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8353
Chris570 wrote:admiral multicar, they halved the cost of renewal of the activa and then mirrored my NCB from the diesel (7years) so it worked out that insuring the HDi, Activa and XM worked out cheaper than insuring just the HDi and Activa
That's precisely why I can afford to keep three Xantias on policy. Admiral really are rather excellent...
So, got to get the XM all on the road by the end of June then Chris... The target is set :)
Chris570
x 36
i'm off for the last 2 weeks of june as well....
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8353
Chris570 wrote:i'm off for the last 2 weeks of june as well....
Ahh, so time for one final bout of the spanner therapy before she rolls out in all her glory onto the Queen's highway then... Perfect :)
Chris570
x 36
well at least 2 really as the strut tops need to come off and then be sent off and be refitted ;)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
Chris570
x 36
WORDS CANNOT DESCRIBE HOW F*CKED OFF I AM WITH THIS XM :twisted: :twisted: :twisted: :cry: :cry:
HG has blown massively, explains where the coolant has been going. Engine won't run at all,water jets 12 inches high. Engine now needs to be swapped, just as I've been finalising it
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
