Side light bulb's (Update)
Alec B
Well I've finally changed them. It ended up being a bumper off job as I just could not get either in, even the nearside with the battery out! The reason the nearside wouldn't go in was because some numpty replaced the bulb but didn't push it all the way back in so it melted the holder. I managed to clear the hole with a dremel. With the headlights out I couldn't belive how easy they were to fit. Also to be safe I fitted new Dipped + Main beam bulbs (all Osram extra life bulbs) so that I didn't have to do them later on! Even doing these other bulbs was a pain and would never have been done in situ. Good luck to anyone doing this job!!!!
Current Car
C5 Estate VTR 1.6HDi 2005 S2
Previous French Cars
Pug 205 Gti 1.6 1985.
Xantia Estate LX 2000 90bhp HDi
Xsara Picasso VTX 1.6 HDi (92) 2007
Citroenmad
- x 110
Re: Side light bulb's (Update)
Good job getting the bumper off, mine stumped me, even armed with the Haynes BoL!
Ive done many sidelights on C5IIs and a few headlamp bulbs now, all in situ and in a matter of minutes
Maybe I should make a video of it next time
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
bxzx16v
- x 34
Previously done the headlamp bulbs on both my S1 C5's awkward but not too bad , you want to try a n/s bulb change on a laguna II , a b**** of a job
Mark
Mark
Citroenmad
- x 110
C5IIs are worse for bulb changes than the C5I, which are a bit of a fiddle and when I first did one it required some shouting
Try a headlamp bulb change on a ScenicII
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Alec B
YES PLEASE
The only thing is you need 2 people to remove and 3 to refit. When all unscrewed it slides forward DON'T pull the sides out as they have locating clips that will break if pulled away from the wings.Good job getting the bumper off, mine stumped me, even armed with the Haynes BoL!![]()
Although it seems owning a Renault could be even worse
Current Car
Lighty
- x 34
I had a C5 11 in for Sidelights a while ago and the bulb holders were melted very badly. The car had Xenons, and the Citroen system said sidelight bulb holders not a liable for Xenon lights. New lamps were loads of money.
I took a Chance and ordered bulb olders for the non hid option, and thankfully they were the same.
Still pricey at around £30 per holder.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Gregg1100
- x 5
Do what my son does with his VTR C5 when a sidelight /headlight goes- takes it to Halfrauds, pays about £6 and let them have the grief
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Lighty
- x 34
Except they will break the fittings, fit the bulb upside down ( headlamps) etc etc, they do it's near to my garage, so I know .Gregg1100 wrote:Do what my son does with his VTR C5 when a sidelight /headlight goes- takes it to Halfrauds, pays about £6 and let them have the grief![]()
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
JohnD
- x 72
When a sidelight bulb went on my C511 less than a year from new, I took it to Halfords. The guy referred to his computer and said they don't do that model. I tried myself for what seemed like hours. Eventually I removed the bumper. 18 months later it was necessary to remove it again. At the third time I decided to fit LED side bulbs and they are lasting well.Gregg1100 wrote: when a sidelight /headlight goes- takes it to Halfrauds,
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
addo
- Sara Watson's Stalker
- x 95
Gregg1100
- x 5
They fit bulbs to C5 in Cwmbran
Alec B
Which LEDs did you get? I bought some on ebay for a cooker hood and within 10 mins of being switched on they had melted and were about 1 min away from catching on fire so I'm wary about which ones to buy, I would like to get good quality ones.When a sidelight bulb went on my C511 less than a year from new, I took it to Halfords. The guy referred to his computer and said they don't do that model. I tried myself for what seemed like hours. Eventually I removed the bumper. 18 months later it was necessary to remove it again. At the third time I decided to fit LED side bulbs and they are lasting well.
Current Car
JohnD
- x 72
Alec B wrote: Which LEDs did you get? .
These:- http://www.amazon.co.uk/gp/product/B004 ... 00TA4923YW" onclick="window.open(this.href);return false;
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Citroenmad
- x 110
Do they give a pure white light?JohnD wrote:Alec B wrote: Which LEDs did you get? .
I got some but they were more blue and illuminated less of the sidelight shape, so I took them back out.
LED:
Normal:
Both:
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
triumphtoledo
I have a C5II and the sidelight bulbs have never worked. Would it be possible to fit an LED strip to the stock bulb holder. It would be a far more effective method of illumination, compared to having one bulb at the top of the headlamp?
R
R
