Xantia electric windows not working.
numnuts
Hi everyone. As I mentioned in a previous post I recently had to change the driver door on my Xantia (2 litre turbo diesel HDI W reg). Now neither of the power windows are working. The drivers side has been temperamental since someone reversed into my door, but the passenger one has always been okay. Now none work, not even the switch on the passenger door. The fuses look fine so I think it could be a relay. Does anyone know where to find the relay for the power windows on this model please? I know there are a few beneath the fascia fuse box some green and one large red one. I haven't yet replaced the door card until I can sort this out. Would really appreciate any advice. Thanks in advance.
- x 8305
Re: Xantia electric windows not working.
I'd say, knowing the quality of the Xantia wiring that in manoeuvring the door wiring around you've broken a few... If it was temperamental before then there's a good chance there was a break starting and the bending you would have to have done on the loom has now finished it off...
Here's a circuit diagram of the front electric windows..
And a harness diagram...
Not forgetting a component location diagram...
A wiring break in the driver's door can affect the passenger as you have a switch for the passenger's door on the driver's door too...
Hope the diagrams help you crack it...
numnuts
Hi. Thanks for that. The broken wire scenario is something I was dreading! Thanks for the diagrams also, though truth be told they are a little beyond me. Take care.T
- x 1240
The switches can also fail, try dousing them with WD40 then giving them a good work out.
numnuts
Thanks all, it was the broken wire scenario. A bitch to fix (Unless you have three hands and fingers like pipe cleaners). Did it though. Thanks for the advice.....Now I just have to find the radio code!
