It turns out that the hand brake caliper mech is seized and as a result the return spring is no longer man enough to cope. The brake now sticks despite now being freed off. I'd like to restore the spring effect but wager that it can't be bought separate tho I will investigate.
Any tips? The mot is in a few weeks.
Also the rh cable is routed wrong but can sort at the time.
xantia hand brake issue
aerodynamica
- x 215
Graeme M
KennyW
- x 165
Re: Xantia hand brake issue
Graeme,
When you say hand brake caliper is seized, do you mean the where the cable fits onto the brake caliper itself.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
KennyW
- x 165
Graeme,
http://service.citroen.com/docapv/AC/im ... 512350.jpg" onclick="window.open(this.href);return false;
See attached photo and confirm if it is the 'hook' which the cable goes into.
Kenny
Kenny
aerodynamica
- x 215
It's the lever-actuator that the cable end locates in. It sticks terribly and has been since before I bought it last August. Now the thing is freed off but the spring has lost its tension. Sorry, couldn't view the picture.
Graeme M
Xaccers
- x 188
So if you disconnect the cable and use some grips to move the lever the cable end sits in, it sticks wherever you set it?
DIY sphere tool
DIY sphere tool
aerodynamica
- x 215
It sticks anywhere from half way to rest position. It's freed off now but the spring is duff but it will return the lever from fully applied to about 4mm off. Needs grips to pull it further and so leaves the cable end slack when handbrake released.
Graeme M
- x 1485
Graeme,
There is a service kit available:
KIT EMERG BRAKE
95 667 819
- 5 DOOR SALOON AND DIESEL XUD9 UNTIL RPO 06901
02 - 5 DOOR SALOON AND TURBO DIESEL XUD9TE
4427 96
- 5 DOOR SALOON AND DIESEL XUD9 SINCE RPO 06902
02 - 5 DOOR SALOON AND DIESEL TURBO XUD9SD
Both priced around £68 - might be easier / cheaper to get a re-con caliper....
KIT EMERG BRAKE
95 667 819
4427 96
aerodynamica
- x 215
Blimey, thanks for the info Richard
Graeme M
VertVega
- x 13
Did you check the condition and amount of the grease under the big black rubber protector cap?aerodynamica wrote:... Now the thing is freed off but the spring has lost its tension. ...
It is fixed with a cable tier. Cut the cable tier and lift up the cap. Clean the remaining grease.
There might be some rust if water or humidity has gone through. The spring will be seen
and check the condition of it. It should move easily by moving the lever by hand.
After cleaning, fill with new grease.
Edit: and a pic where the rubber cap is seen.
xmexclusive
Similar handbrake arrangement on the XM.
Temporary fix for same handbrake cable problem was to fit the cable end through a long strong return spring.
John
John
Xmexclusive
aerodynamica
- x 215
Thanks guys, yes I've had the rubber cap off. It has been plus gassed to free off but needs packed with new grease.
The extra spring idea; is it a coil spring fitted between the lever and cable stop like on a CX? Cable travels through the spring?
Graeme M
xmexclusive
Yes.
Was done by one of the club members to solve the MOT fail on insecure cable problem.
John
John
Xmexclusive
Harry1975
i had the same problem, pull cable out get some pliers on the hook and move it back and forward a lot that should un-seize it, if not get on ebay there are some caliper repair kits on there, if not a second hand break caliper, should get one for under £35 easy to fit and bleed
