Thanks Chris, whats up with the A/C? not terminal i hope!
D
Dean's Activa/XM/V6 and now Talbot blog
Deanxm
- x 87
Re: Dean's Activa/XM blog
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Chris570
- x 36
no gas in there at all, and if i try to force the compressor on it wont engage so first port of call is change that. I'm hoping that both problems are caused by the compressor
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
OnlineCitroJim
- x 8411
Citroenmad
- x 110
Well done on the MOT front Dean, you can sit back and enjoy it now. Well, until it decides what to fill your spare time with next
Working air con is a must!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
OnlineCitroJim
- x 8411
What news of the XM Dean?Deanxm wrote: time to get back to the xm![]()
robin92
Hi!
Were you found your chrome rings around the gauges?
And how you manage to get the 15psi in boost?
Xantia Activa 2.0 tct -96, Xantia Activa v6 - 00
Sorry for my bad English;)
Deanxm
- x 87
The chrome dial surrounds can be found for sale Here
On mine I removed the stock boost controller and replaced it with a manual one, well the controller was in the car when i got it but is was piped up a bit wrong.
boost can be changed while diving as there is a boost guage fitted in the car also.
D
D
XM Prestige PRV6 92
robin92
same here I have a manually boost controller. But my boost are on MAX 10psi.
Maybe the dump valve are broken and release the boost air. I have recirculating dump valve, it looks like yours but mine are mounted on other way :S
Deanxm
- x 87
Is your boost controller a bleed or seated bearing type?
D
D
XM Prestige PRV6 92
robin92
I dont now :/ But it is this http://www.google.se/imgres?hl=sv&biw=1 ... =115&ty=70" onclick="window.open(this.href);return false;Deanxm wrote:Is your boost controller a bleed or seated bearing type?
D
Deanxm
- x 87
Looks like a bleed type to me, the trouble you can have is that the air cannot bleed away fast enough at high boost levels and the wastegate still gets opened, try making a restriction in the pipe between the throttle intake pipe and the boost controller, this will allow a smaller volume of air to move through the boost control valve and allow you to set higher boost levels, i had to do it to mine especialy if you have it set up in car where the pipe runs can be rather long.
Another thing could be that the spring in the wastgate actuator is broken or soft and pressure in the exaust manifold is pushing it open slightly under hard acceleration, most activas now will be suffering from wastgate creap if the actuator has not been looked after.
D
D
XM Prestige PRV6 92
robin92
do you now if the spring in wg are possible to change?
Deanxm
- x 87
No i dont think you can, most of the time the arm just wants re adjusting as the spring softens, you can feel if there is any slop in the actuator arm.
D
D
XM Prestige PRV6 92
robin92
okey I will look it up.
btw
nice car!
btw
nice car!
Deanxm
- x 87
Thank you.
Did you get the hydraulics on yours sorted in the end?
D
D
XM Prestige PRV6 92
