p reg synergie starting issue
dave2011
Unread post by dave2011 »
hi guys.im back with yet another problem with the damn thing lol.a coulpe of weeks ago my synergie had a starting fault that turned out to be a bad earth on the battery that i found out about after i folked out for a new battery. :evil: this time i have a similar issue....... bright lights on the dash and a click behind the glove box....... is this a dodgie relay or a duff ignition barrel? the car starts most of the time but sometimes it needs the key to be switched off and on a few times before the starter will crank over.any ideas guys? thanks in advance 8-)
x 8343
Re: p reg synergie starting issue
This is a common problem on the V6 Xantia amongst others and indeed it's an intermittent high resistance in the starter solenoid wiring, including a high resistance in the ignition switch.
The cure is to install a 'helper' relay so that the ignition switch only operates a relay and is relieved of the duties of carrying the full starter solenoid current. Feed the starter solenoid relay direct from the battery via a fuse.
dave2011
cheers jim. :@) i dont suppose there is a wiring diagram on the forum for it is there or shall i google it? cheers again :@)
x 8343
I only have one for the V6 showing the modified wiring.
Modified V6 Starter Circuit
That should give you an idea of how to wire it Dave...
dave2011
nice one jim cheers :)
