c5 radio
DickieG
- Monaco's youngest playboy
- x 38
Re: c5 radio
Sounds like a wiring issue, a few minutes reading the radio installation manual and a voltmeter should sort it out, make sure the ignition live feed is correctly wired to the appropriate wire on the radio.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Robert12
Re: c5 radio
thanks for the reply, there is two wires 0n the radio loom red & yellow swopped them round its keeping its memory now
when i turn the key off there seems to be a long delay before the radio gows off
DickieG
- x 38
Re: c5 radio
As long as it turns off in a reasonable length of time I wouldn't worry, quite a few accessories take a while to shut down these days.Robert12 wrote:when i turn the key off there seems to be a long delay before the radio gows off
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1045
Re: c5 radio
The ignition live feed for the radio is wired to the cars VAN+ supply, there is no ignition live at the radio plug. The connectors might look the same on the car & on the new radio but that doesent mean its plug & play.
Have a read here > http://www.frenchcarforum.co.uk/forum/v ... ex#p270057" onclick="window.open(this.href);return false;.
P.S. you might have read elsewhere that you need a lexia to do this properly,If you have its not true.
As far as taking a few minutes to switch off goes isnt a big problem but if the cars multiplex data wires are connected to a different radio you can get other problems like battery drains,central locking faults, multifunction display freezing.DickieG wrote: As long as it turns off in a reasonable length of time I wouldn't worry, quite a few accessories take a while to shut down these days.
BX
- x 19
Re: c5 radio
Take the ignition supply from the back of the cigarette lighter socket to your new radio. If you use the one for the Citroen radio you might get funnies like the BSI not going to sleep and return to the car to find your battery flat. Same applies when fitting phone kits.
Edit: Wheeler has already given you the correct info. Next time I will read the full thread before jumping in.
reblack68
Re: c5 radio
Does anybody have the pin-out for the C5's radio plug. I had several possible "battery" feeds when I checked with my voltmeter. I chose the one that didn't change when the ignition was turned on (the others all dropped considerably) and took the "ignition" feed from the lighter as suggested. The radio worked as it should but the display would freeze (usually with the N from "door open") until the button on the wiper was pressed, after which it would work fine. I took that to be a quirk, but now the car is going into Eco Mode when parked up- although the radio had been in for a couple of weeks when this started happening.
It's one of those radios that turns off with the ignition but can be turned on again with the ignition off, which is how most radios work nowadays.
Any thoughts?
Any thoughts?
Richard
No French cars of my own at present.
Care of a 1994 205 D.
reblack68
Re: c5 radio
Found it. http://www.c5club.cz/files/pdf/PU-2472A.pdf" onclick="window.open(this.href);return false;
Richard
