My XM V6 ES9
lexi
x 134
Re: My XM V6.... She Lives!!!
Unread post by lexi »
Congrats on breathing life into the beast. All the more so with working outside in what has been winter. =D>
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Chris570
x 36
Re: My XM V6.... She Lives! In true XM fashion is on a death
Unread post by Chris570 »
I took last friday off to get some proper work done on the XM, my plan was to get her moving under her own steam...
To make this happen meant the following had to happen
-Remove hubs
-Change swivel joints
-Replace track rod ends
-Replace Droplinks
The XM (Now named as the blue whale by Jess) had other ideas....
The track rod end on the n/s had seized up a treat so only some VERY careful angle grinding could free her off. Upon undoing the caliper to hub bolts it took a solid 5 mins of hammering to get the caliper off the disc (leaving the friction material intact) the o/s took 20 mins and a prybar.
Then the swivel joints themselves wouldnt undo with a 5ft extention bar, Liam (Hydrocobra) popped round and between us we managed to get one off with me pushing the bar onto the hub and him practically jumping on it. It was tight all the way off!! Here's a pic to show you the amount of force...
Then came the turn of the second hub....
This happened....
In so doing it chewed up the swivel joint so badly a tool could no longer be used. Cue massive swearing.
Now you may have noticed in the first pic that the brake disc was still attached. It was, but not by means of retaining screws, oh no. This is the XM remember (soon becoming a swear word). After a good 10 mins with a lump hammer I could not (nor Liam) get the discs off the hubs. So I popped round to see Mr Jim to borrow his press. Between 5-6 Tonnes of pressure was needed to shift them, needless to say we were both in shock over this. We also discovered that at least one of the wheel bearings is sh*gged, possibly down to the lump hammer. So that was game over for the dream of having her back on her wheels this weekend.
I also found that the N/S abs sensor is actually dead so needs replacement so if anyone knows where to find one cheap please let me know :)
Despite everything I am NOT letting the XM win, she will run again like it or not.
/rant
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
x 8237
Good work Chris :-D It shocked me how much force those discs needed to cone free. Good old Scottish corrosion :lol:
That wheel bearing was already knackered. No amount of what you or I did that. Pop round and I'll press 'em out for you although gawd knows what fun that'll be :twisted:
Still, she's coming on nice :-D
Chris570
x 36
my wallet is now wimpering/hiding after ordering 2 bearings.
i wouldnt be so sure that the bearing damage isnt hammer related, at the Citroen Service Centre the whole lot took a big beating from the hammer, if the disc was hit outwards with the carrier clamped it would exert the force on the hub/bearing
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I should have a 605 NSF ABS sensor in uncorroded state. It had a swim in muddy fresh water but never ice or road salt. PM me if you'd like it.
As to the wheel bearings - aren't they the same as Xantia?
Chris570
x 36
Oh i forgot to mention, the swivel joint is still stuck in one of the hubs, they are tough buggers with very very strong casings, i'm sending it off to an engineering firm to have a driveshaft nut welded onto the casing so hopefully that'll shift the b@stard.
If anyone else has any other tips for removing them i'm all ears :)
Nope the bearings are different unfortunately. the same as a non ABS 605 i think.
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
xmexclusive
Unread post by xmexclusive »
From memory XM front wheel bearings changed size about 1997.
Late XM is Teves Mk4 or Teves Mk20 ABS.
Teves Mk4 was also used on some Xantias.
The Teves sensors are usually branded ATE and cheap compared to the Bendix ones of the early XM's.
Pug 605 has a different ABS.
John
Xmexclusive
Chris570
x 36
yep they did change around then, the earlier type seem a lot cheaper, which is annoying, at least i won't have to change them very often i guess.
you've reminded me, mine is a Mk20
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
addo
x 95
It doesn't look as if any of the sensors interchange with 605. Bugger.
xmexclusive wrote:Pug 605 has a different ABS and you need to book a hard braking application several weeks in advance.
Chris570
x 36
Thank you for your kind offer anyway :)
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi Chris..
What an interesting read! Cant beleve how hard you find working and removing engines from these girls! Ive had two PRV V6s out now, one my 12v auto, the other my 24v manual...
Bottom ball joints... simple.. I HEAT them... I heat them on the joint itself and melt the rubber and grease, while at the same time this melts the locktite on the threads, but remember to ALSO bend out the locked edges between the hub and joint... so in theroy theres two locked methods...
Xantia S2 used Tevis 20 systems, with an all plastic sensor, where as early Mk.1 Xantias used a metal coated house. My guess is your XM needs a S2 type xantia sensor... relativly cheap on ebay. John (xmexclusive)s your best man for knowledge of sensors though..
Ive sucesfully removed bottom joints with heat without getting the wheel bearing too hot, and they have survived.. though if your fitting bearings then theres no worries!
Paul
A very sad...
1994 XM 2.1 d auto
Chris570
x 36
Thanks for that, i might try extreme heat in conjunction with the welded nut approach.
There is believe it or not more room in a Xantia engine bay with the ES9 than in the XM.
Sorry but the Xantia is a better car all round than the XM.
But the XM makes up for it in it sheer quirkiness, which I like (obviously).
It's here to stay, I keep on being asked if i'll sell her when she's done and the answer is no, i don't think i'd ever find another one and it is a future classic i'm sure.
ABS sensors, now there's a thought....
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
citroenxm
Fallen Hero
x 70
yaaaayy someone who knows a good car...
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
citroenxm wrote:yaaaayy someone who knows a good car...
Don't you mean needs psychiatric help :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
ive had it.. makes no difference...
A very sad...
1994 XM 2.1 d auto
