Height contoler or Sphere Fault
imperial21
Unread post by imperial21 »
Hi All
I am a bit confussed by my Xantia problem, I have recently been putting the Xantia in Low height settings at night to make sure all is ok what i am finding is the car is strugling to raise at the back, The front come up quite quickly but the back would nt come up in the end i moved the leaver to service level and car creaked and judered up, I then set the lever back to normal, Suspension is working ok when driving.
Saturday i worked the car through the height settings and the car would nt come up and the front sphere was clicking maddly, but they dont click when in normal mode.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Lighty
x 34
Re: Height contoler or Sphere Fault
Unread post by Lighty »
Sounds like your height corrector linkages , most likely the rear are sticking, certainly the case for the rear not coming up.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I second Lighty... I wont be the Spheres OR Height corrector itself, but the Linkage levers that control the height corrector itself.. they are a common siezure item on the xantias at the rear. The fronts dont normally and didnt on XUD cars due to common oil leaks from the engines keeping them lubricated...
Have a look at other "Rear height corretor" posts, a little further down for a breakdown diagram of a rear linkage control unit...
A very sad...
1994 XM 2.1 d auto
