Xantia rear Height Corrector - Replacement Seals
gadgetgricey
Unread post by gadgetgricey »
Sorry to double post, but having difficulty in sourcing the above.
Rang my local Citroen Main Dealer, who advised they dont stock them. Had a look on the Citroen parts catalogue on line and cant find any part numbers etc.
Anyone know the part number or where they can be sourced from, as looking to change the rear height controller on my Xantia this weekend. So need a new seal for each pipe.
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
x 94
Re: Xantia rear Height Corrector - Replacement Seals
Unread post by citronut »
try aiming these No.'s at your citroen dealer
5410408 CORRECTOR CUP 3.36 GBP 4.03 GBP 4.03 GBP
5410407 CORRECTOR CUP 2.88 GBP 3.46 GBP 3.46 GBP
5410732 CORR DIAPHRAGM 3.41 GBP 4.09 GBP 4.09 GBP
they are from service citroen under BX but will fit any full blooded hydraulic citroen,
regards malcolm
Foggyoutcome
Unread post by Foggyoutcome »
Can I ask why your changing it.
On mine there is a leak. Would this make the rear right side solid?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
nope.. that would indicate the right sphere has internally burst!! and lost its gas into the lhm system...
A very sad...
1994 XM 2.1 d auto
Rhothgar
(Donor 2026)
x 225
Unread post by Rhothgar »
citronut wrote:they are from service Citroën under BX but will fit any full blooded hydraulic Citroën,
regards malcolm
Useful information there, malcolm. Xantia ones show NFP! So I sourced mine from Pleaides.
gadgetgricey
Sorry did not reply to this. Managed to source them from Citroen at just over a £1 each.
Will try and dig out the part number provided.
Cheers
- Dave -
x 94
regards malcolm
service citroen dont even show the seals and diaphragms as seperate parts, they only show complete H/C'
gadgetgricey wrote:Sorry did not reply to this. Managed to source them from Citroën at just over a £1 each.
Cheers
- Dave -
how did you manage to get them for just over a £1 each then Dave
regards malcolm
gadgetgricey
regards malcolm
No idea :shock:
Rang three citroen places. The first one said they would get back to me. The next two could not find them in stock, hence why I then posted on here.
The next day, the first Citroen place got back to me and advised then had them available.
Popped over and paid just under a £5 for four. (Did not actually use them in the end, as just swapped the cradle)
I'll try and remember to dig the receipt out and get the part numbers.
Cheers
- Dave -
gadgetgricey
Sorry for the delay, hope the following is useful.
Have not used them in the end, but they look as though they are correct.
Cheers
- Dave -
x 94
i thought you were talking about these
but the ones you show arnt just H/C seals but general 3.5mm pipe seals,
im sure Martin at Pleiades sells those for a lot less than the dealer,
regards malcolm
